Old 12-09-2018, 12:23 AM
JFreak JFreak is online now
Default Re: Workaround for E-Guit Recording with HD Native
... except that audio track records before plugins, so you need to send that signal to another audio track for recording
Old 12-09-2018, 12:34 AM
Mark Ziebarth Mark Ziebarth is offline
Thanks to both of you. I will try your tips later today and report back.
Best
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 12-09-2018, 12:35 AM
You don't need to do anything else while tracking. KISS. You want to print that to another track at mix time knock yourself out, reamp with a different amp, ditto. Or commit or freeze... yep have all those options as well. But the OP's problem of monitoring though a plugin... solved.
Old 12-10-2018, 02:05 PM
ProtoolsLover ProtoolsLover is offline
I do what you are describing all the time, feeding both a direct signal and the Kemper signal via separate tracks with zero issues. This is probably the most obvious question, but do you have anything on your Master Buss when doing this? If so, what?
If you are feeding an Aux for Delay and or Reverb, then just put the plugins on the channel you are recording verses an Aux.
Old 12-10-2018, 07:14 PM
As an HDN user, I track direct electric guitars(and bass) all the time with no discernible latency, so there probably is a flaw in your method. The number 1 cause of "almost 2000 samples" of ADC is; a send on a track that actually goes nowhere(imagine; you add a send to feed an AUX track, but you change your mind and delete the AUX track. If the send is still in place, it feeds nothing, which makes ADC go crazy and add almost 2000 samples of ADC). This has hit me several times before I finally pinned down the cause.
I simply record the DI guitar to an AUDIO track with my amp sim of choice in the top slot(usually I use Guitar Rig, but Amplitube and Eleven work the same. Set the buffer to 64 and record just as if I were playing thru a mic'd amp. My bass recording is done similarly, but I record the DI bass to an AUDIO track and this track has a send that feeds a MONO AUX track with Amplitube's SVX amp sim(usually the B15 preset with minor tweaks). Amplitube has 7 samples of latency compensation and nobody has ever had an issue with that small amount of added latency
Old 12-13-2018, 08:36 AM
sorry for getting back that late...
I tried what all of you proposed and... it worked...
I did the Aux Track thing last week as I believed native plugins are muted while recording... This is what I experienced with my HD setup I used till a few weeks ago. I should have checked the new method before...but now I know it’s as easy as with my HD rig. With 64 samples buffer size there is no noticeable latency to me. Great!
Thanks for all your input, I will get better with native systems, I swear...
Best
Mark
Native Instrument Komplete Comp Freeze workaround playground_strifer Tips & Tricks 1 07-16-2013 05:30 AM
tracking elc guit.--gain questions... vicwind General Discussion 3 01-10-2004 06:22 PM
Vocal/Guit amp ISO cab corTools General Discussion 1 01-05-2004 11:32 AM
GR-50 roland guit synth gargoyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-20-2003 05:12 AM
Ac Guit and pick noise ... phobia Tips & Tricks 4 05-31-2000 04:05 PM
