Old 02-25-2020, 01:14 PM
sjgam sjgam is offline
Default Latest Recommendation for Eucon Network Setup
See on various posts recommendations for a 5 G unmanaged switch, a higher level gaming router, dynamic IP or static IP etc.
I dont have a networking problem to present I would just like to have the most stable, reliable network setup for my S1 and Dock with my Mac.
I have a fairly straightforward setup - whats the ideal setup? - I don't mind buying stuff/configuring with new instructions etc
My current setup:
Dock and S1 with two current iPads
2013 Macbook Pro TB into Apple TB Cinema Display
Ethernet cable from Ethernet Port from Apple TB Cinema Display to Unmanaged Switch -D-Link Ethernet Switch, 5 Port Unmanaged Gigabit
Ethernet cables from Switch four remaining ports to Dock and S1 and to each iPad using apple Camera kit and usb ethernet adapter.
Display Ethernet has self assigned IP using DHCP
My setup is at home and I have wifi set up with Google Home Wifi wireless router but I do not use wifi for my Eucon setup so hopefully its snappier with all wired connections.
Is there an even more stable solution than this - static IP, router instead of switch etc that is recommended?
Old 02-26-2020, 07:26 AM
EddieJones's Avatar
Default Re: Latest Recommendation for Eucon Network Setup
This setup (All EUCON on same network) is good. Are you having any issues ?
Old 02-26-2020, 10:39 AM
No not in any relation to network - I just see recommendations on this forum about manual IP setup as opposed to dynamic and also gaming level routers as opposed to my 5G unmanaged switch and would like to have the optimal recommended setup.
Old 02-26-2020, 10:49 AM
EddieJones's Avatar
If you have a reasonable router or direct connection (setup right) things are good. There are many reasons why it can go bad so trying Static IP's and a new router are all trouble shooting tips and not needed if things are working.
Old 02-26-2020, 03:26 PM
Ok thanks for that guidance - I will stick with 5G unmanaged switch (not a router) and DHCP (not static IP).
Eucon Network connection not found walter rohrbach Avid S1, S3, Dock and Control App 2 07-19-2016 08:04 AM
Latest A/D Recommendation? misterphoneman Third Party Interfaces 7 03-16-2015 10:53 AM
Network Problems with Eucon?? peterle Artist Series 0 01-01-2015 04:12 AM
EUCON network services could not be started... bgervais Artist Series 2 11-06-2014 08:52 AM
