Old 05-19-2016, 04:21 AM
Acidstorm's Avatar
Acidstorm Acidstorm is offline
Default Pro Tools Complete Midi CC# Chart
To Control PT12 with my generic Midi Controler....
i have setup a list with all the CC# used and free and found some Dead CC#
i thought i will share the list so you can see what CC# are free to programm with your plugins side a side to the Transport Control:
(Setup Descriped at the end)
Free Programmable CC# : 75 (0-11,16,25-32,42-48,58-63,65-73,79-108,112,119)
Pro Tools Fixed CC# : 39 (12-15,17-24,33-41.49-57,109-111,113-118)
Dead CC# (Not working) : 14 (64,74-78,120-127)
CC# 0-127 =
CC# 0
CC# 1
CC# 2
CC# 3
CC# 4
CC# 5
CC# 6
CC# 7
CC# 8
CC# 9
CC# 10
CC# 11
CC# 12 – mute selected track
CC# 13 – solo selected track
CC# 14 – move bank left
CC# 15 – move bank right
CC# 16
CC# 17 – Pan knob 1 (incremental/endless)
CC# 18 – Pan knob 2 (incremental/endless)
CC# 19 – Pan knob 3 (incremental/endless)
CC# 20 – Pan knob 4 (incremental/endless)
CC# 21 – Pan knob 5 (incremental/endless)
CC# 22 – Pan knob 6 (incremental/endless)
CC# 23 – Pan knob 7 (incremental/endless)
CC# 24 – Pan knob 8 (incremental/endless)
CC# 25
CC# 26
CC# 27
CC# 28
CC# 29
CC# 30
CC# 31
CC# 32
CC# 33 – Fader 1
CC# 34 – Fader 2
CC# 35 – Fader 3
CC# 36 – Fader 4
CC# 37 – Fader 5
CC# 38 – Fader 6
CC# 39 – Fader 7
CC# 40 – Fader 8
CC# 41 – Master Fader
CC# 42
CC# 43
CC# 44
CC# 45
CC# 46
CC# 47
CC# 48
CC# 49 – Slider Button 1
CC# 50 – Slider Button 2
CC# 51 – Slider Button 3
CC# 52 – Slider Button 4
CC# 53 – Slider Button 5
CC# 54 – Slider Button 6
CC# 55 – Slider Button 7
CC# 56 – Slider Button 8
CC# 57 – Flip button
CC# 58
CC# 59
CC# 60
CC# 61
CC# 62
CC# 63
CC# 64 --- NOT WORKING! ---
CC# 65
CC# 66
CC# 67
CC# 68
CC# 69
CC# 70
CC# 71
CC# 72
CC# 73
CC# 74 --- NOT WORKING! ---
CC# 75 --- NOT WORKING! ---
CC# 76 --- NOT WORKING! ---
CC# 77 --- NOT WORKING! ---
CC# 78 --- NOT WORKING! ---
CC# 79
CC# 80
CC# 81
CC# 82
CC# 83
CC# 84
CC# 85
CC# 86
CC# 87
CC# 88
CC# 89
CC# 90
CC# 91
CC# 92
CC# 93
CC# 94
CC# 95
CC# 96
CC# 97
CC# 98
CC# 99
CC# 100
CC# 101
CC# 102
CC# 103
CC# 104
CC# 105
CC# 106
CC# 107
CC# 108
CC# 109 – Mode button
CC# 110 – Prev track
CC# 111 – Next track
CC# 112
CC# 113 – Loop button
CC# 114 – Rewind
CC# 115 – Fast Forward
CC# 116 – Stop
CC# 117 – Play
CC# 118 – Record
CC# 119
CC# 120 --- NOT WORKING! ---
CC# 121 --- NOT WORKING! ---
CC# 122 --- NOT WORKING! ---
CC# 123 --- NOT WORKING! ---
CC# 124 --- NOT WORKING! ---
CC# 125 --- NOT WORKING! ---
CC# 126 --- NOT WORKING! ---
CC# 127 --- NOT WORKING! ---
Setting up a Generic Midi controler for ProTools 12 =
1. Open ProTools and go to Setup > Peripherals > MIDI Controllers
2. Add a controller
Type: M-Audio Keyboard
To : CONTROLLER VIRTUAL IN
#Chs: 8
Here is a list of the CC#s used . You can use these values to set up other controllers or create your own scenes.
CC#
14 – move bank left
17 thru 24 – Pan knobs (incremental/endless)
33 thru 40 – faders
41 – master fader
49 thru 56 – Slider Buttons
57 – Flip button
109 – Mode button
110 – Prev track
111 – Next track
113 – Loop button
114 – Rewind
115 – Fast Forward
116 – Stop
117 – Play
118 – Record
Transport:
All transport buttons map to their corresponding buttons in Pro Tools. Play, stop, rewind, forward and record act as you would expect in in PT8′s transport window. Holding the loop button while pressing the transport keys gives more options. Loop + Play enables loop play, and Loop + Record enables loop record. Loop + Stop will undo the last action and Loop + RR or FF moves to the beginning or end of the song.
Sliders 1-8
Sliders 1-8 control the corresponding sliders in Protools. The sliders are controlled in banks of 8.8. The bank will change if you select a track outside of the current bank of 8, or if you use the change bank buttons.
Slider 9
Maps the rightmost master fader.
Pan Knobs 1-8
The knobs unfortunately are not emulated correctly. This is due to the fact the Axiom 61 uses “endless” knobs while the nanoKontrol uses absolute knobs. The knobs can reliably give settings of full left, centered or full right. Normally the knobs are mapped to pan controls, though this can change
Upper button row
1 – < Track (Previous Track)
2 – Track > (Next Track)
3 – < Bank (Previous Bank)
4 – Bank > (Next Bank)
5 – unused
6 – unused
7 – Mute selected
8 – Solo Selected
9 – Mode Button
The Mode button switches between mixer mode and insert mode. When in Mixer mode the nanoKontrol’s knobs control PT8′s mixer pan knobs. In insert mode the knobs are used to control plug in knobs or settings.
Lower Button row
1 thru 8 – Slider buttons
9 – Flip button
In mixer mode the flip button switches the use of the slider buttons between these functions:
Select track
Arm track to record
Mute track
Solo track
In insert mode, the flip button switches the functions of the pan and slider knobs.
How to control Plug ins with the nanoKontrol
Most users will probably be satisfied being able to use the transport and sliders with the basic button functions. If you would like to also edit plug in controls, you need to enable the Insertmode with the mode button. In insert mode, you can use the knobs to change the values of the plug in controls. Unfortunately though, knob emulation doesn’t work very well with the nanoKontrol. You can use the flip button in Insert Mode to switch the function of the knobs and sliders. Then the sliders will control the plug in (and the knobs will control PT mixer faders). This can get a little confusing because there are no visual indicators on the nanoKontrol to let you know the status of the Mode or Flip buttons.
Finally, if you want to use the knobs to correctly control the plug ins, I swapped the CC#s of the sliders and faders between Scene 1 and Scene 2 (Scene 3 and 4 are copies of 1 and 2).
Workflows:
To edit plug ins with sliders
1. Press Mode
2. Press Flip
3. Enable Scene 1 or 3
To edit plug ins with knobs
1. Press Mode
2. Press Flip
3. Enable Scene 2 or 4
- Darkpsy - Ambient - Electronic Psychedelic -
_/|_/|_/|_/|_/|_/|_/|_/|_/|_/|_/|_/|_/|_/|_/|_/|_
_/Pro Tools 12.2/Imac El Capitan/RME Fireface 400
_/Midi Fighter Twister/Event 2020BAS/Waldorf Pulse 2
_/FFProQ2,Waves,Uhbik,Nave,Komplete 10U,Aeon,Exhale
Old 05-19-2016, 04:23 AM
Acidstorm's Avatar
Default Re: Pro Tools Complete Midi CC# Chart
Print Sheet =
Programmable Midi CC# CHART
Plugin = _________________
Rotary Encoder (or any)
CC# 0________________________
CC# 1________________________
CC# 2________________________
CC# 3________________________
CC# 4________________________
CC# 5________________________
CC# 6________________________
CC# 7________________________
CC# 8________________________
CC# 25_______________________
CC# 26_______________________
CC# 27_______________________
CC# 28_______________________
CC# 29_______________________
CC# 30_______________________
CC# 31_______________________
CC# 32_______________________
CC# 42_______________________
CC# 43_______________________
CC# 44_______________________
CC# 45_______________________
CC# 46_______________________
CC# 47_______________________
CC# 48_______________________
CC# 58_______________________
CC# 59_______________________
CC# 60_______________________
CC# 61_______________________
CC# 62_______________________
CC# 63_______________________
CC# 65_______________________
CC# 66_______________________
CC# 67_______________________
CC# 68_______________________
CC# 69_______________________
CC# 70_______________________
CC# 71_______________________
CC# 72_______________________
CC# 73_______________________
CC# 79_______________________
CC# 80_______________________
Switch Encoder (or any)
CC# 9________________________
CC# 10_______________________
CC# 11_______________________
CC# 16_______________________
CC# 81_______________________
CC# 82_______________________
CC# 83_______________________
CC# 84_______________________
CC# 85_______________________
CC# 86_______________________
CC# 87_______________________
CC# 88_______________________
CC# 89_______________________
CC# 90_______________________
CC# 91_______________________
CC# 92_______________________
CC# 93_______________________
CC# 94_______________________
CC# 95_______________________
CC# 96_______________________
CC# 97_______________________
CC# 98_______________________
CC# 99_______________________
CC# 100______________________
CC# 101______________________
CC# 102______________________
CC# 103______________________
CC# 104______________________
CC# 105______________________
CC# 106______________________
CC# 107______________________
CC# 108______________________
CC# 112______________________
CC# 119______________________
Old 05-19-2016, 04:56 AM
You do know that several of your controller settings conflict with standard MIDI cc uses right? For instance cc33 is mod wheel, cc34 is breath control, etc. I suggest you take a look at these links:
http://web.archive.org/web/200707021...ntrollers.html
http://www.nortonmusic.com/midi_cc.html
Jack
QAPLA!
Old 05-19-2016, 05:05 AM
Acidstorm's Avatar
checked it but that does apply only if you NOT chose the Controler on Pheriphials.....if you use the controler with the M-Audio protocol things are mapped different...as in the list Pro Tools do use CC#33 for Fader 1 when set as controler in pheriphials with M-audio
Old 05-20-2016, 06:05 AM
What is 'M-Audio protocol'?
Jack
QAPLA!
Old 05-20-2016, 09:36 AM
clausiii's Avatar
clausiii clausiii is offline
It was called Hypercontrol.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 05-28-2016, 06:58 PM
salmonsound salmonsound is offline
I've been obsessing over this the last few days. I bought a CODE-61 and hoped it would be an upgrade from the AXIOM PRO-25. Lost all the glorious Hypercontrol things like:
Show/Hide Plugin
Scroll through sends, plugins
and I just cannot get the FLIP button CC to take hold... I really wanted to control the knobs inside plugins with real knobs on the CODE but stuck...
I think I might try a reverse-lookup MIDI program, to see if I can hack it. Are folks still messing around with this?
Recording # Editing # Mixing # Mastering
SALMON SOUND
Studio # Mobile # Online
http://www.salmonsound.com
Old 05-29-2016, 02:15 AM
clausiii's Avatar
Show/Hide Plugin
yes Hypercontrol was great (when it worked)!
did you try to use the CODE-61 as an "M-Audio Keyboard" device in the Peripherals/MIDI Controller setup of PT?
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 05-29-2016, 07:58 AM
Yes I have, and had some success but the transport controls went black. I am still learning how to operate the CODE-61. If I set it up as M-Audio Keyboard within PT, I get some interesting results, scrolling through presets on the CODE - evidence that lots of cool things can be controlled.
I've been able to set up next and previous track, which is cool. I wanted to be able to re-program the bank and transport buttons on the CODE, but it seems not possible.
Man, Hypercontrol is so nice. I just got to the point where I was flying around on the AXIOM PRO 25 and hardly using the mouse, but the pitch bend died and started sending bogus messages, so I sold it. Hence the upgrade to CODE, but I should have just bought a PRO 61.
I swear I'm going to get this to work...
SALMON SOUND
Old 11-07-2016, 07:34 PM
snape snape is offline
Thanks for this, just got a novation launch control to use with PT11.x. I wanted something to control my native instruments synth parameters and it worked like a charm. Thanks so much for posting.
ERXP::Scrolling past the last page of MIDI CC Chart will crash TieDyedDevil Eleven Rack 2 03-25-2011 08:22 PM
Pro Tools 9 Compatibilty Chart tg4878 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 11-29-2010 08:44 AM
Pro Tools LE and HD Comparison Chart? Dizzi45Z Tips & Tricks 3 05-26-2008 12:13 PM
HUI midi implementation chart Hogie MIDI 3 10-03-2005 09:11 AM
Mackie HUI MIDI Specifications - Midi implementation chart yamyyy Pro Tools TDM Systems (Mac) 2 05-31-2001 07:16 AM
