Re: Unable to play any midi instrument I own
Make sure you are viewing the instrument panel in the track. not just insert, send, and i/o.
It sounds like this is assigned correctly. If you imported a session sometimes the output gets an italicized alias output in the i/o panel where the aforementioned sends and inserts are. This needs to be changed to a real output(non italicized) but even so you should hear it but it wouldn't render correctly. You could go to the i/o preferences and just click default. Then double check that you have real outputs.
Dave Cournoyer-guitarist-project studio Mac Mini late 2012, i7, Sierra 16GB PT10.3.10HD PT12.5.2 Apogee Mini-Me firewire. |
Thanks for the help, i'll try that too , this has been really frustrating, other daws are plug an play, this thing is driving me crazy , this is like the fourth time i try to come back to the pro tools word, but i get nothing but deceptions, i'll give pt one more chance, but the way pt went crazy when i runed arturia analog lab .....last version of course. For now i'm just relaxing , on monday i'll continue working on my trusty daw......logicx. Cheers
Nehalem 2.66 quad core, 32 Gig RAM , 640GB , 2TB Seagate, OSx10.8.5, PTHD10.3.8, HD3 Accel, MidiIO, 192, 96i, Pre |
Are the controllers enabled under setup>midi>input devices? The boxes for your keyboards should be ticked.
Yes I did all that, same problem happened, a few months ago when i downloaded pt11's demo, no midi.....Now, a popup shows up (pro tools is unable to communicate with m-audio keyboard) funny thing...... |
#16
Try downloading a fresh copy of the m-audio drivers and installing them again.
#17
I downloaded M-audio's enigmaXXL archive, installed the drivers, nothing changes
#18
I'm glad I suscribed for one month.......
midi doesn't work.....that's it good bye |
#19
Hi relixtinian and moonmusic, et. al,
I too am in the same boat, with 'Pro Tools 2019.12.0'? Pro Tools 'Set Up' sees the differing small MIDI keyboards that I own (e.g. I tried an Op-1, MINILAB MkII and NOVATION 25), but even with the Default MIDI Preference set to 'first selected MIDI track'... NOTHING? I can tap on the virtual keys and know that the virtual instruments are playing correctly, but nothing re connectivity with the external MIDI keyboard? These all work seamlessly in other DAW's (e.g. ABLETON 10). So what have I missed? Kind regards, :-R |
PT recognizes midi controller, will not play instrument | RaySoul | Pro Tools 11 | 6 | 09-05-2013 10:03 PM |
Unable to resize mini-keyboard to the same on instrument & midi tracks | foxes | macOS | 4 | 07-07-2013 01:20 PM |
unable to play Vacuum via instrument track | 440Hz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 36 | 06-03-2010 11:34 PM |
How do I get a MIDI track to play an Instrument | higginsdj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 05-16-2010 04:20 AM |
MIDI and Instrument Tracks won't play back | joshuadanger | MIDI | 7 | 01-07-2010 01:47 PM |
