Old 04-23-2015, 11:03 AM
reflixtinian reflixtinian is offline
Default Unable to play any midi instrument I own
So I just got pro tools 12, and I've spent 3 days trying to find out how to put my keyboard controllers to work on pt12, I did everything i read on gearslutz, youtube, etc but nothing......My controllers are m-audio axiom 61 and Arturia minilab, those work fine with logic in different computers, but not in pt 12.
I asigned the controllers on peripherals, did the mixer thing, midi thru thing,used different usb ports, etc etc but nothing, please HELP
My system: mac pro late 2013, uad apollo,
Old 04-23-2015, 11:32 AM
gonsdeejay's Avatar
gonsdeejay gonsdeejay is offline
Default Re: Unable to play any midi instrument I own
Hi Réflex, Go to Pro Tools Preferences, In the MIDI Tab, Default Thru MIDI Instrument to : First Selected MIDI Track.... I Hope with this setting, Your MIDI Controller Works...!
Cheers!
Pro Tools 2021.12 UAudio Apollo X8, 8 Duo & Apollo Twin. Mac mini M1 8 on Ram, 256gb, Thunderbolt 3 KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Producing My Own Life
Old 04-23-2015, 11:41 AM
feliponk's Avatar
feliponk feliponk is offline
Hi: are the controllers being shown in the Audio/Midi setup application?
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 04-23-2015, 02:12 PM
Thanks for the answers, yes I can see all my controllers (midi input devices) but nothing happens.. by the way I'm on Yosemite 10.10.2 .
Old 04-23-2015, 02:41 PM
Southsidemusic's Avatar
Just to make sure - you have record enabled the VI (Instrument track) and still nothing?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 04-23-2015, 02:45 PM
Yes, record enabled....nothing happens
Old 04-23-2015, 03:00 PM
feliponk's Avatar
Hi: yesterday I have faced a similar situation, and it was one VI that was causing this weird behavior, Kontakt 5 AAX. Once removed from the session, everything worked fine again.
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
Old 04-23-2015, 03:09 PM
Emcha_audio's Avatar
On the instrument track, have you set the midi input selector to the actual instruments you are using? You see them in the midi studio set up, but you need to assign them to the track you want to it. If you leave the track midi input selector to all, then you might get problems.. for instance double notes being triggered.
https://www.youtube.com/watch?v=xwFM0LfCsH0
this explains the step of assigning your usb controller to the midi track.
Manny.
Wave-T.com
Old 04-23-2015, 06:18 PM
thank you , I've tried all that, but nothing..
Old 04-23-2015, 06:21 PM
moonmusic moonmusic is offline
I'm not sure off the top of my head but I'm thinking there is an audio/midi setup in your utility folder on a Mac...I'd try messing with that if you've already tried everything in PT....moon
Nehalem 2.66 quad core, 32 Gig RAM , 640GB , 2TB Seagate, OSx10.8.5, PTHD10.3.8, HD3 Accel, MidiIO, 192, 96i, Pre
PT recognizes midi controller, will not play instrument RaySoul Pro Tools 11 6 09-05-2013 10:03 PM
Unable to resize mini-keyboard to the same on instrument & midi tracks foxes macOS 4 07-07-2013 01:20 PM
unable to play Vacuum via instrument track 440Hz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 36 06-03-2010 11:34 PM
How do I get a MIDI track to play an Instrument higginsdj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 05-16-2010 04:20 AM
MIDI and Instrument Tracks won't play back joshuadanger MIDI 7 01-07-2010 01:47 PM
