Old 10-29-2020, 07:44 AM
nymills nymills is offline
Default Ctrl F/crossfades issue
Ctrl F is working for Fade In/Out but not crossfades. Don't know what happened. Was working then suddenly had limitations. Confident this is a settings issue. Any help would be muchly appreciated!
Thank you!
Michael
Old 10-29-2020, 07:54 AM
Default Re: Ctrl F/crossfades issue
It's possible that there is a very tiny fade already there, zoom in really close to the edit point to check. This has gotten me many times in the past.
Scott Gatteño
Yessian
Old 10-29-2020, 12:17 PM
daeron80 daeron80 is offline
Must be Windows. On my Windows machine, the system occasionally acts as if one or more modifier keys is stuck, causing commands that use those keys to stop working. Often, I can clear it by hitting the modifier key twice. But it tends to be only a workaround, for which the only fix is to reboot. I should note that my keyboard is an ancient PS2 type. Still works great, though I wonder if it could be the source of my problem. Maybe sometimes it fails to send the release stroke.
David J. Finnamore
Nyquist was right.
PT 2020.11.0 Ultimate | Omni | macOS Mojave
PT 2020.9.1 | Saffire Pro 40 | Win10
Crossfades issue TMMusic Pro Tools 10 4 05-17-2017 10:19 AM
Crossfades distorting and export errors... Serious issue! Arno Peeters Pro Tools 12 1 01-03-2016 10:02 AM
Issue when consolidate or AudioSuite crossfades Jperkins Pro Tools 12 10 07-01-2015 02:46 PM
Ctrl+Scrub Wheel issue kptkarl ICON & C|24 6 11-03-2011 05:51 PM
CTRL 24 Mac OS X Monitor Issue MikeyK Pro Tools TDM Systems (Mac) 3 01-21-2009 10:45 AM
