Old 09-18-2019, 01:27 PM
subwoof subwoof is offline
Default Waves V10 vs V9
Sorry if this has been covered previously, but I haven't WUP'd since V9. Does Waves V10 offer any obvious advantages in performance or functionality over V9 for Pro Tools 2019.6.0 and HDX? Thanks!
Michael McDonough, M.P.S.E.
Michael McDonough Sound Design
Old 09-18-2019, 01:34 PM
Default Re: Waves V10 vs V9
One thing to keep in mind is that any new plugins you buy from Waves is V10
Jack
QAPLA!
Old 09-18-2019, 01:37 PM
JFreak's Avatar
JFreak JFreak is online now
Not yet, but you likely want to be current when you update to Catalina
Janne
Old 09-18-2019, 02:10 PM
BScout BScout is offline
No difference other than new plugins only come out on V10.
You can run v9 side by side to v10 (though Waves is sneaky and tries to get you to change those v9 to v10 during the install process of v10 plugins -- just reject that.) You can still get the v9 installers from Waves (who acknowledge you can run them side by side.)
There's likely no issue between it and Catalina either -- the plugins are 64 bit already in v9. So it only matters about the version installer. v9 installer is not 64 bit. v10 is 64 bit. So if you need to do an new install once on Catalina, you are going to have problems with the v9 installer (if you upgrade in place you shouldn't because you wouldn't have to run the installer)
Old 09-18-2019, 03:56 PM
AlexLakis AlexLakis is offline
I can't stress this caveat enough, they almost got me with this. Be careful!
Old 09-19-2019, 03:25 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Long list of V9 and V10 changes here
https://www.waves.com/downloads/release-notes
I'm still running V9 for Mercury but everything else on V10.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 09-19-2019, 03:29 AM
JFreak's Avatar
Most of them SoundGrid related, so if you don't use SG and pay WUP you could just as easily burn money.
Janne
Old 11-02-2019, 05:33 AM
simon.a.billington simon.a.billington is offline
...vs V11 now!!!
To the best of my knowledge it's 64-bit only and I think needed for Catalina compatibility. They seemed to have reskinned the Renaissance plugins.... FINALLY!! The old UI was hideous and unwieldy to work with, put me off ever using them. I might give them a go now.
With the Renaissance reskinned and those few plugins they released for their 25th Anniversary, hear'ed hoping that there will be more reskins to come!!
Old 12-23-2019, 06:13 AM
crazy_jorgito crazy_jorgito is offline
Therefore if I update to Catalina and I don't need to install any new plugins, I can still use the waves 9.6 plugins right? Has anyone tried this?
Thanks!
- MackBook Pro Late 2016 (TouchBar):
Intel Core i7 @ 2,6 GHz (Turbo Boost @ 3,5 GHz)
16 GB RAM @ 2.133 MHz
Radeon Pro 460 with 4 GB of memory (graphics card)
SSD PCIe 512 GB
- Apollo Twin Duo MKII (2016) Thunderbolt
- Pro Tools 12.8.1
Old 01-07-2020, 05:05 AM
Thanks!
No.... V9.6 wont run in Catalina, only V11 do.
So you'll need to pay for an update if you want to use Catalina or, maybe upgrade to a (bigger) bundle which will also give you more plugins for the money.
HTML code is On
FS: Waves Kramer Master Tape and other Waves plugins MatthieuH Buy & Sell 0 05-16-2016 08:57 AM
Waves license not found after Waves update Talisker Pro Tools 10 5 03-26-2014 09:14 AM
Not enough space on Waves only ilok to download Waves update 7 crizdee Pro Tools TDM Systems (Mac) 38 11-09-2009 05:19 PM
Plugs Advice: Sony vs Waves - Sonalksis vs Waves? John J. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-08-2005 01:31 PM
WAVES Protools7 update and Waves tech support x9blade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 11-11-2005 06:24 PM
