Old 11-23-2011, 08:22 AM
crizdee's Avatar
crizdee crizdee is offline
Exclamation Pro Tools requires the DSP mixer plugin in the plugins folder!!!!!!
I've run the installer 2 times now and get this message that the DSP mixer plugin is missing? and PT won't open of course.
I've checked the plugins folder but no show
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-23-2011, 08:36 AM
Kris75's Avatar
Kris75 Kris75 is offline
Space Cabin Audio
Default Re: Pro Tools requires the DSP mixer plugin in the plugins folder!!!!!!
When you install PT10 don't choose the custom option. This bit me in the butt. Once you install it not using the custom option, the mixer plug in **should** be there.
Sign up for all things....AWESOME!
Kris
May the music move you
Old 11-23-2011, 11:25 AM
marrap's Avatar
marrap marrap is offline
no DSP Mixer Plug In found in my Plug Ins folder.
But I have no access to my HD rig, my MBP with HD
installed, but without HD hardware, has no DSP Mixer plug installed.
Didn’t use custom location.
PT HD 10 works fine.
wolfgang funk
marrakech prod
www.marrakechprod.com
www.linkedin.com/in/marrakechprod
https://pro-labs.imdb.com/name/nm3047395
Mac Pro 2.8, 8 Core,16 GIG Ram, PT HD 10 - 12. Mac Book Pro 2.6 Retina 16 GIG Ram, Artist Control/MIX.
Old 11-23-2011, 11:26 AM
crizdee's Avatar
After 2 attempts at installing i uninstalled and installed again and now i have the surround dithered mixer, so at least PT opens now. But i'll have to find out whats happened with the stereo mixer.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-23-2011, 11:36 AM
marrap's Avatar
Surround Mixer installed here ?!
No Stereo Mixer.
wolfgang funk
marrakech prod
Old 11-23-2011, 12:11 PM
Carl Kolchak Carl Kolchak is offline
Originally Posted by crizdee View Post
Chris
Have you looked in the "unused plugins" folder?
I have most variants of the mixer (dithered stereo / surround dithered / surround non-dithered) in there on my laptop, not using hardware.
Old 11-23-2011, 12:15 PM
crizdee's Avatar
yes i just suddenly remembered! surprised it defaulted to surround mixer though.
just need to find disk cache now
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-23-2011, 01:46 PM
Firechild Firechild is offline
playback engine I guess.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7
Old 11-23-2011, 02:45 PM
crizdee's Avatar
Yes, as i said in my other post it just looked like the old DAE playback buffer, so didn't realize that was it. will be checking it out more tomorrow.
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-02-2021, 12:57 PM
MFred MFred is offline
Hi !
I have the exact same issue and I've done everything you said
( Clean Reinstall, Launch Protools pressing the "N" key and choose " HDX" playback engine, even reinstall Moutain Lion + Protools on another drive )
Nothing works !!!
Protools is still asking for this DSP Mixer Plug and close...
IDK what to do
If anyone has an idea ?
Thx
Help! Pro Tools won't start Pro Tools with TDM requires the TDM mixer plug-in in plug Winterland Pro Tools TDM Systems (Mac) 9 08-12-2009 12:42 PM
Message "Pro tools with tdm requires the tdm mixer plug-in in the plugins folder" Alexei Zaitsev Pro Tools TDM Systems (Win) 0 01-10-2009 03:48 AM
UAD TDM PLUGINS NOT FOUND IN PLUGIN FOLDER heromusic Pro Tools TDM Systems (Mac) 1 03-13-2008 02:24 AM
plugins in my folder but not in pro tools musiceng711 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-12-2007 09:20 PM
6.7 requires TDM mixer Plug-in??? Glenn75 Pro Tools TDM Systems (Mac) 3 11-05-2004 10:24 PM
