MOTU 8pre
I have just purchased the MOTU 8pre and I would like some feedback about it. I will be using it with my Pro Tools 9 LE system.
Also is there anything I need to install before I start using it or I can just plug and play? |
Re: MOTU 8pre
If it's your main interface, you'll have to install the drivers for it. Should be included, or you can get them from MOTU.com. You will also probably want to use the Cue Mix software for low-latency monitoring.
If you are just adding it to an Avid interface via light-pipe, I think it will just show up as additional optical inputs.
Save early and often! (or once a day whether you need to or not...) |
Re: MOTU 8pre
What do you want to know? I have a pair of them.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
Re: MOTU 8pre
I will be using it as my main interface. I figure that MOTU is a little better then the Mbox, which has been faithful to me so far.
Re: MOTU 8pre
Are the preamps good? Is there headroom? Is it an upgrade from an Mbox? How is the quality?
Re: MOTU 8pre
You will rarely find a significant difference in the preamplifiers of these low-priced boxes. Most are adequate, which is all you can hope for.
MOTU 8pre
I have two MOTU 8Pre's and wondered if you guys can help me link them to have 16inputs. At the moment I'm just daisy chaining them with a firewire cable. Is this correct or do I have to use cables from the optical ins and outs? At the moment I can use them both through pro tools, but I can only use one or the other. Which is kinda useless. Thanks!!
Re: MOTU 8pre
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
MOTU 8pre
Okay thanks, so just to clarify. I need 4 ADAT cables going from the standalone units output into the interfaces input and then from the interfaces output into the standalone units input? I don't no if this is correct because I've only connect the standalone units output into the interfaces input and nothing is happening. I copied what this person did in this video, he seems to have it working. I don't no if I've done it correct and I'm just being stupid and can't get it to work.
http://www.youtube.com/watch?v=y4hyW-edmhI Skip to 1 minuet 50 seconds! THANKS!!!!! |
Re: MOTU 8pre
Yes - ins to outs, outs to ins between the units. Four cables if you want full 88.2/96k capability ADAT A and B - only two if you want max 44.1/48k ADAT A. Try the two cable setup connecting ADAT A (1-8) ins and outs first (same as the Youtube video). Don't forget to disconnect the stanalone unit from firewire and clock it to ADAT. When you open CueMix FX you should see signal coming in from the standalone on ADAT 1-8.
MOTU 8PRE via Optical | [email protected] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-28-2009 03:17 PM |
Is it possible to use a Motu 8Pre with ProTools? | bobtastic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-14-2008 10:49 PM |
Using MOTU 8pre with 002 | hutchypie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-10-2008 05:28 PM |
Motu 8pre to 002 via ADAT?? Help! | linchpinc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 05-18-2007 07:42 AM |
Motu 8pre to 002 via ADAT?? Help! | linchpinc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-18-2007 04:26 AM |
