Old 02-14-2006, 09:02 AM
Cawbaby Cawbaby is offline
Default Trouble installing PT7.0
OK, get this. I've tried 3 different drives, erased them and freshly installed OS 10.4. I've tried this several times on 2 of these drives. I got PT 7.0 to install only twice without freezing. It always freezes with 397 files remaining to install. When I update to 7.1cs4, after the 2 times I was successful installing PT 7.0 the installer freezes with 396 files remaining to be installed. I've put Toast, Jam, Quickeys, and probably 4 or 5 additional small apps on these drives with no problem but the Pro Tools installer freezes. I thought it might be the actual CD install disc so digi sent me a digidelivery disc image and I installed from there. It froze for a few seconds at 397 files installedbut then sqeeked by and loaded. Then of course 7.1cs4 froze.
Anyway after I force quit the installer the amount USED in the info of the start-up drive continues to grow. So I'm forced to erase HD and start over.
Anybody have any ideas. Tech support appears to be tapped but I will try them again.
thanx
Craig
10.4.3 G4 dual 1.25 2G ram
Dr. Caw Recording
www.drcaw.com
Old 02-14-2006, 11:39 AM
DigiTechSupt's Avatar
Default Re: Trouble installing PT7.0
I would recommend trying to install from a new admin account. We've seen this a couple times before and installing from a different admin account seems to fix the problem.
Avid Audio Tech Support
Support FAQ
Old 02-14-2006, 11:57 AM
Thanx, but I did try this and it did load PT 7.0 but failed on the 7.1cs4 update. Thanx for the response, it's nice to see people concerned.
Dr. Caw Recording
www.drcaw.com
Help, I have trouble installing my HD2 on my Mac OS X juanpastudios Pro Tools TDM Systems (Mac) 6 05-29-2012 02:20 PM
trouble installing matte81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-31-2010 09:32 AM
trouble installing 7.4 LE on xp rpacheco6 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-03-2009 02:06 AM
Trouble installing the ilok HELP! neversleep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-08-2007 09:47 AM
Trouble installing PT 5.3.1 Dave Steinwedel Pro Tools TDM Systems (Mac) 1 09-06-2003 02:44 PM
