message reads I/O setup has changed since last time session was opened last time
Message says: I/O setup has changed since the last time the session was saved, check I/O setups window to see what has changed. 002 stays in standby, all ins, outs, sends inactive, help.
Re: message reads I/O setup has changed since last time session was opened last time
Power harness?
hello, i have the same problem since i disconnected my /mbox 3's usb cable, i try to do the default settings as well on the setup I/O menu and nothing all i get its sound from the speaker of my mac and nothing from the interface what is this?? please help me
Why don't you create a separate thread for your problem in a Mac forum. Even if you were on Windows piling onto a thread for somebody else's problem that may or may not be related is likely to end up in a confusing jumble of replies. Please read the "Help us Help You - READ THIS Before Posting!" link at the top of this page. You will tend to get much better help from folks if you include as much of the info asked there. Be clear exactly what version of Pro Tools version and as much info on your Mac hardware etc. as possible. If you are running Pro Tools 9 (as I suspect) post to the Pro Tools 9 mac forum. Darryl |
thanks
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Right. I don't know if these different forum parts are called "areas", "groups", "forums" etc. DUC is the overall forum and under DUC somewhere here you'll find folks to help, but you make it easier if you post in the most appropriate area/forum/group/... and provide as much info as possible.
People here generally really want to help other folks out but the most frustrating threads are those with two or more different problems intertwined where folks with problems are providing lots of useful info and others are trying to help but things just get confused -- its often better to post things in separate threads unless they are really clearly the same problem (not just the same error message). Darryl |
"Your I/O setup has changed since the last time" ...WTF | Rectifried | Pro Tools 11 | 4 | 02-03-2014 11:39 AM |
Your I/O setup has changed since the last time this session | awalls | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-05-2011 07:49 PM |
EVERY time I open a session I get the message that my I/O setting has changed | papitopinillo | macOS | 2 | 06-27-2011 09:06 PM |
Strike - Content Not Found Message When Opened 1st Time | SHC | Virtual Instruments | 2 | 05-10-2007 07:56 AM |
Why tempo reset each time session opened | nortstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-08-2007 03:38 PM |
