automation bypass bug
try this:
-instaciate a waves deesser -automation enable bypass -bypass it -close the session, reopen it -try to un-bypass the plug.... doesn't work -deactivate it (control-command-click), and reactivate it -everything is back to normal... I'm having this for quite some versions now, and I am surprised that nobody else mentioned it.. It's quite annoying if one bypasses a plug by automating it, and after reopening it's just doing nothing anymore... it happens with quite a few plugs here: waves deesser, L2, fairchild 660/670, sonalksys dc1, phoenix, I'm shure there's more... anyone ? best regards- |
Re: automation bypass bug
Hi Phil,
This actually happens with the Waves C1 Comp-Gate as well. I'm always careful not to bypass plug ins unless I'm sure it doesn't exhibit the bug. Peace, Brandon
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
thanx brandon,
glad not to be the only one.... ;-) is Digi aware of this ? Thanx for taking care ! regards- |
Yes, we are aware of this - this seems to be related to having automation on the track. If you play back at a transition point for 'bypass' (either going from 'on' to 'off' or vice versa) the bypass button will suddenly work again.
We are, obviously, looking for a fix for this... |
hello digi,
any news about this... ? I just realized that in 7.2 even mcdsp-plugs don't un-bypass anymore when automated... ;-/ regards- ph!L |
How do you Bypass a plug in using automation? | HipHopWong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-24-2013 09:24 PM |
Is there a way to bypass the new automation behabiour of 10.3? | tj_davies | Pro Tools 10 | 0 | 09-24-2012 07:27 AM |
Bypass Automation Bug - Please Verify | KingFish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-26-2009 07:35 AM |
Plug-in BYPASS automation | dmh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-27-2008 07:01 PM |
Automation-bypass bug ? | phil2000 | Pro Tools TDM Systems (Mac) | 0 | 02-15-2006 02:50 AM |
