Old 11-12-2005, 05:14 PM
David Every David Every is offline
Default How to create a \"template\" session ?
Hi all
I need to get Pro Tools 6.4 set up for a new 16 track song really quickly, without having to add all the tracks and set up all the inputs to the various tracks. Is there a way to do this ? Can I copy a previously setup "template" session or something like that ?
any help appreciated ...
thanks
David E
Old 11-12-2005, 06:46 PM
Default Re: How to create a \"template\" session ?
on p.c.'s you have to create your session and set it up how you want it, then close out of it. that will be your template. then you have to create your new session, name it, yada yada, then under file, import session data. when that window opens you should be able to make sense of what to check, all of your tracks will be listed on your bottom left hand side and choose what to import. i cant recall it much better without looking at it.... hope that helps some. somebody i'm sure will give you better details.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 11-12-2005, 07:53 PM
macr0w macr0w is offline
After you get the session set up how you want it, close it and go to the properties of the file and change it to be a read only file.
Intel I7 920
Asus P6T
Digi 002R.
Command/8
PTLE 7.1 MPT
www.clearspotrecording.com
"Create Session from Template" --> not showing CR92 Pro Tools 11 0 12-24-2013 06:05 PM
How do you create a Session template ? kt90 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-13-2009 02:05 PM
How...Create New session with Session Template TDelmar Tips & Tricks 5 10-22-2008 08:29 PM
How do I create a Mix or Session Template? dougied 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-17-2008 05:38 AM
How do you create a session template in protools7? JAKE @ LOUD Pro Tools TDM Systems (Mac) 3 06-24-2006 08:43 AM
