Waveform
When you select a piece of audio and make a volume adjustment is it possible to see the waveform get bigger and smaller as you adjust in volume view as opposed to waveform view?
I can see the waveform get bigger or smaller when I adjust clip gain in waveform view but is it possible in volume view. I’m running Win Pro Tools version 10.3.9. |
Re: Waveform
unfortunately not possible.
frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: Waveform
You could convert your volume to clip gain, its a nice feature.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
Re: Waveform
Not sure why but a lots of dots in the the clip gain blows up your session size significantly. Also: Once coalaced to clip gain it's extremely cumbersome to continue to mix for obvious reasons. So you'll be constantly coalescing back and forth between volume and clip-gain if you want to mix like that. Frank.
Re: Waveform
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Re: Waveform
Hmmm. Good to know guys.
I don't do it myself, I just thought it might solve pseudo's problem, clearly not! I did look at my memory usage the other day on PT11 for the first time in a long while and I was using 16gigs!!!! I'm guessing that session will not open in PT10.
Calculate waveform - where are waveform views stored? | levelaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-11-2010 07:18 AM |
Waveform | BasilF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-25-2009 02:08 PM |
Waveform Help | andyj4308 | Pro Tools TDM Systems (Mac) | 2 | 06-16-2008 07:53 AM |
No waveform | whinolovechild | Pro Tools M-Powered (Mac) | 0 | 01-06-2007 05:57 AM |
Waveform only goes up ? | Vic D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-07-2004 01:43 AM |
