  #51
Old 10-27-2012, 05:15 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Pro Tools 10 on Windows 8??
Originally Posted by dts350z View Post
I searched duc for all the disk cache error posts. The only fix I found (actually stopped looking after finding this) was running the installer as admin.
I tried that with no joy, after uninstalling and reboot.
Today I installed the release version of windows 8 (using windows 8 upgrade tool), which I assume set me back to "zero" as no programs came across with the upgrade (only personal files). Tried again to install Pro Tools as admin but I'm still stuck at the disk cache error during startup.
Yes I know there's posts saying that installing protools 9 and then uinstalling works but I don't have access to PT 9 installer anymore.
Don't know what to tell ya. I'm running W8 Pro and PT9 just fine here. I did an in place upgrade from 7 Ultimate to 8 Pro, only had to re-install a couple programs. Pro Tools ran just fine without needing to be reinstalled.
Its strange that PT9 runs pretty well on W8, but PT10 doesn't.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
  #52
Old 10-28-2012, 09:25 PM
zion zion is offline
Pro Tools 10.3.2 is running fine on Windows 8 Pro Here.
  #53
Old 10-30-2012, 03:17 AM
TheJamsh TheJamsh is offline
Originally Posted by filosofem View Post
Avid have not Qualified Windows 8 for Pro Tools.
There's something fundamentally wrong with that quote... Shouldn't it read 'Avid have not updated Pro Tools for Windows 8'? I hate the mentality that systems should adjust to Pro Tools.
Anyway, if you plan on getting Windows 8 as soon as it releases, you're asking for trouble. Wait until at least the first service pack comes out, or give it a few months for the initial bugs to be squashed. To be honest, I'd rather keep my PC a PC, rather than a glorified tablet, so I'll be sticking with Windows 7 for a long time yet.
www.anvilaudio.co.uk - PC Users: Buy Skootch, you won't regret it.
PC: Windows 7 64-Bit, ASRock Extreme 4 x79 Mobo, Intel Core i7-3820K @3.6Ghz, Kingston HyperX 16GB Ram, OCZ Vertex 3 64GB SSD, WD Caviar Green 2TB HDD, GeForce 560Ti GPU, SIIG TI Firewire Card, PT Keyboard.
O/B: Focusrite Liquid Saffire 56, Focusrite Liquid Mix 32, Alesis D4 Drum Module, Alesis MIDIVerb4, M-Audio Axiom 49 v2, M-Audio BX8a's, Audix DP7
  #54
Old 10-30-2012, 06:42 AM
JamesClark1991 JamesClark1991 is offline
This.
This not so much... Windows 8 is an improvement on W7 for desktops imo. After 1 week or so you want to go back. Loving the release preview (except PT10 doesn't work!!!!!! ¬_¬)
  #55
Old 10-30-2012, 08:10 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
... I hate the mentality that systems should adjust to Pro Tools...
Pro Tools is not a consumer application.
"Qualified" means that one can safely install a particular combination of hardware, OS and Pro Tools version into the most demanding professional post production and music recording environments. The folks who bill $500+ an hour simply can't afford running across obscure bugs.
Avid has an extensive qualification process that everything must pass before a given combination is considered officially "qualified." Obviously even with all this some problems slip through so many facilities hang a year behind in both OS and Pro Tools versions. They and Avid can't afford being on the bleeding edge.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
  #56
Old 10-30-2012, 08:14 AM
Benoni's Avatar
Cool man, is that with the HD|Native card?
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
  #57
Old 10-30-2012, 09:08 AM
paulloebmusic paulloebmusic is offline
Thumbs up Re: Pro Tools 10 on Windows 8??
I have Windows 8, Pro Tools 10.3.2, and I had the same problem with the "disk cache" error upon launch, even when running as an administrator. I can confirm that I solved the problem and am now able to run PT10 with no errors by re-installing Pro Tools 9 "on top" of an existing Pro Tools 10.3.2.
Download my latest song for free! Click here: http://PaulLoeb.net
  #58
Old 10-30-2012, 02:25 PM
junkgear's Avatar
junkgear junkgear is offline
Now sombody needs to figure out what PT9 puts on the system to make 10 run
  #59
Old 10-30-2012, 02:46 PM
Yep! The only thing, when you install Pro Tools 10.3.2 you have to install the HD driver separately. You can find it in the Pro Tools 10 Folder in Program Files(86). The only thing that is not working in Windows 8 is my Solid State Logic Plugins because there is a need for a codemeter update. So I'm wating on SSL for that. But my Waves, Uad, Native-Instruments (including Kontakt 5), Voxengo plugins work fine. The only thing you have to overcome in Win8 is the security setting on the harddrive files and folders. Set all your audio apps to Run with the Administrator Privileges .
  #60
Old 10-31-2012, 05:44 AM
Benoni's Avatar
Cool, cool, good to know Native is working. And yes, disable UAC, set up PT to run as admin.
Tell me, when you updated, did you do an in place upgrade (Keep Everything) or did you do Keep Nothing? Or did you install from a disc. I installed from within the Windows Upgrade Adviser because thats the only way the license number I had would activate (bought the 7 to 8 upgrade online) without going in to the reg later and changing a 1 to a 0. I also chose to 'keep everything' because I was dreading having to type in all those plugin license codes, usually I would do a clean install, but since 8 is pretty similar to 7 I thought I would give an in place upgrade a try this time, and so far its working pretty good. A few problems, but those should be fixed by updated drivers.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Pro Tools 11 on Windows 7 or Windows 8? ianbee Windows 6 08-15-2013 04:04 PM
Upgrade From Pro Tools LE (Windows XP) to 10 (Windows 7) miek07 Windows 3 07-26-2012 07:49 PM
Updating Pro Tools and Mbox from Windows XP to Windows 7 ryanjantz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-29-2011 04:22 PM
Opening a pro-tools HD session on a windows Pro-Tools LE M-powered system rhodamorgan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-21-2010 05:31 PM
Pro Tools LE vs. Pro Tools M-Audio - Any difference? Windows 7 gbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-21-2009 08:24 PM
