Pt 10+ liquid saffire 56+ saffire pro 40 masterclock?
So after renting the liquid a few times I decided I would go ahead and just purchase it (LS56), with 1 or 2 Saffire pro 40, or something else with 8 pre's to get a total of 24 pre's on the ready. But I'm wondering if the liquid world clock is good enough to be the master clock or if I should get an outboard master clock. Anyone has had problems with it or any thoughts on it?
Windows 7 ultimate 64 sp1. intel i5 2500k 3.30 ghz. asus p8p67 evo rev 3. 16g kingston ddr3 1600. Asus engtx 560dc2 oc. Seagate Barracuda 7200 9 SATA 80-GB Hard Drive. 2x WD caviar black 7200 500 GB. 1x WD caviar black 7200 1 TB. Seagate Freeagent 7200 1 TB usb 2.0. SIIG NN-440012-S8. PT 10. SIB 7. ProjectMix I/O. Focusrite Liquid Saffire 56. Focusrite Saffire pro 40. Genelec 8040. Axiom pro 61. Alesis Dm8 pro. Spector ns2000/5. Old vintage Vantage electric guitar. Bunch of VI's and plugins
Re: Pt 10+ liquid saffire 56+ saffire pro 40 masterclock?
http://global.focusrite.com/mic-pres/octopre-mkii By the way, the Octopre can be used in S-MUX mode for 96K: "Digital Channel Outputs:
An LS56 plus 2 Octopres would be a pretty cool setup. I'm currently using my LS56 along with a Presonus Digimax (8 additional pres via ADAT, clocked to the LS56 via Word Clock). It all works/sounds good.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Will it matter? I've read and been told by Focusright that I could still slave the pro 40 to the ls56 through the spdif or the optical. I'm glad thought that you seem to say that the clock of ls56 is good.
I also found this on their answer-base forum just now since you had me jump hehehe. Why doesn't Saffire have a wordclock input? In the applications for which the Saffire was designed, wordclock connections are not needed. Synchronisation is only needed if timing is crucial (for example when doing 'laybacks' of audio in post production), or if there are several digital devices being used simultaneously. With the Saffire, the only sources being recorded will be the analogue inputs and/or SPDIF signals. Therefore the only digital sources that will need synchronizing are devices connected to the SPDIF In. In this case no wordclock connection is needed, as wordclock is embedded within the SPDIF signal from the digital source and the Saffire will sync to this.
I also would recommend the OctoPre Mk II Dynamic. Ebay has them (usually) for just over $500 for new B stock.
I see. I was hoping that I wouldn't have any problem with the pro 40 and the ls56 since they have the same pre's and I have a lot of recordings coming up that will require me having 16 pre's at a minimum, a lot of classical stuff so was looking for the same pre's to get the same clear sound from pre 1 to pre 16. That would have given it to me with the sf56 and pro 40 combo, they have the same pre's. I might change to the octo pre later then, but do you two foresee any problems with this combo for now? The units have already been ordered, under the impression that I would have been able to sync them through the spdif or adat.
Right so I got into a mad dash trying to get a firm answer from focusright, and here's what they have said.
To achieve this, you'll need LS56 + two Octopres, and wordclock to sync all 3 devices. You can use the Pro 40/LS56 combo as Focusrite said, but that's 2 devices (not 3) and 16 mic pres (not 24).
Yes I meant for now, until I'm ready to go to 24 pre's
protools 10 + liquid saffire 56 problem
hello everybody
i am new to this forum posting , i hope i am in the right place. i have a problem with my liquid saffire 56 interface, i tweaked all my system . system:- processor : intel core i7-2600K CPU @ 3.40 GHz RAM : 16GB DDR3 VGA card : ATI Radeon HD 5870 Os: windows 7 ultimate 64bit i had to buy a firewire card , and when i run the OHCI tool .. it says Vendor : (104C) Texas Instruments Chipset: (8025) TSB82AA2B/TSB83AA22A/TSB83AA23 Revision: 01 Max 1394 Speed Capability: S800 Support: Compatible, no known issues. Done. so it is supposed to be compatible , though when i run mix control 3 . it gives me .. no hardware connected , although everything is plugged , sometimes it is connected sometimes it just disconnects. mainly after i open PT10 everything is updated , all the drivers .. i cant seem to know what is causing the problem .. i would really appreciate some help thanks all |
Liquid Saffire 56 and Digi002 | dave911 | Third Party Interfaces | 8 | 05-15-2013 01:11 PM |
Liquid saffire 56 setup | mal777 | Third Party Interfaces | 1 | 04-19-2013 04:33 PM |
PT9/003 Factory/Liquid Saffire 56? | Judicious | macOS | 6 | 07-20-2011 09:00 AM |
saffire pro 40 vs liquid saffire 56 | AxeDye | Pro Tools 9 | 9 | 12-09-2010 05:19 PM |
liquid saffire 56 | AxeDye | Pro Tools 9 | 2 | 11-19-2010 04:28 PM |
