Old 08-14-2019, 02:13 PM
Brian Hudson Brian Hudson is offline
Default Bounce direct to SoundCloud as MP3
Would it be possible to bounce a final mix direct to the SoundCloud platform as an MP3
Brian Hudson
Old 08-14-2019, 09:03 PM
cwsand's Avatar
cwsand cwsand is online now
Default Re: Bounce direct to SoundCloud as MP3
I think you could in older versions, but not 2018 IIRC.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 08-14-2019, 11:07 PM
Sardi Sardi is offline
Yeah you could from memory.
Not really that much more time consuming bouncing and then uploading the file.
Old 08-15-2019, 09:04 AM
Something related to this can one only bounce to MP3 my setup always bounces to one of the choosable output types and the MP3 is an optional extra
Brian Hudson
Old 08-15-2019, 03:43 PM
Yes you can.
Uncheck the mp3 check box and then when you click on the format drop down box, you’ll see wav, aiff etc. and mp3 will be in there.
If you desire, bouncing that way will only render an mp3.
Old 08-15-2019, 09:57 PM
Thanks so much will try this, I’d like to know how much discernible difference there is between MP3 and more conventional output types because we always try and save on storage space and transmission capacity
Brian Hudson
Soundcloud ? BCnSTL Pro Tools 11 0 06-30-2014 10:44 AM
Bounce to Disk issues and bounce to direct show error. SeattleHank Windows 7 01-01-2014 12:41 PM
SoundCloud: How do you use it? gavriil1 Pro Tools 10 10 11-26-2012 04:01 PM
SoundCloud -no so hot! NewdestinyX Pro Tools 10 21 03-03-2012 06:36 AM
Bounce To Disk or monitor out direct to ext. CDR? KennyD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 33 08-13-2001 07:24 PM
