  #21
Old 06-29-2018, 10:36 AM
Stig Eliassen's Avatar
Default Re: midi bug: cannot delete one note !
Originally Posted by Stig Eliassen View Post
No problem. How about export, then re-import?
... and, what if you export to a different drive, then import it? It's such a weird problem...
  #22
Old 06-29-2018, 12:04 PM
skizzo skizzo is offline
I can't see the video but after you said you cannot move it at all, any chance it is "locked" to prevent movement and/or deletion? There will be a small padlock looking icon in the bottom corner of the region the note is in
Mac Pro '09 - 5,1 - Dual Hex Core X5680 3.33 ghz CPU - 48GB RAM
970EVO 500GB (10.13.6) - 1TB WD Black HDD (Samples) - 6TB Toshiba HDD (Backups) - 500GB Glyph GT050Q (Legacy sessions & backups) - 3TB Glyph Studio (Main audio/sessions)
HD5770 GPU
OSX 10.13.6 - Pro Tools 2018.12 - Presonus Studio 192 / Digi 003 Rack+
Focusrite Clarett OctoPre - AKG HPE6 - DBX160A - WA76
  #23
Old 06-29-2018, 12:33 PM
PhiBee's Avatar
PhiBee PhiBee is offline
Hi !
No, no padlock at all. And in that specific region, no problem with the other notes. Just ONE note
I just received a mail from Avid Customer Care. I’ll send them my session. Wait and see
WIP house Prod - home studio
iMAC - Pro Tools Ultimate 2022.6 - RME Digiface USB - Audient iD22 - Behringer ADA8200 - Digidesign C|8 - NI KK A61
STUDIO PRO Post-prod
MAC Pro "Trash can" - Pro Tools HDX + Ultimate 2021.12/Avid C|24/S3/ProTools|Dock. Blackmagic.
  #24
Old 06-29-2018, 01:28 PM
DJKeys's Avatar
DJKeys DJKeys is offline
Just curious, Have you tried deletion using a key command instead of the context menu?
-dj
iMAC 3.2GHz 6-core i7
250GB SSD (internal)
1TB SSD (external)
16GB RAM
OSX 10.14.5
PT 2019.10 (last one)
Waves Gold/RenMaxx v11
iZotope Ozone 8
Focusrite Clarett 8Pre
Nord Stage 3
Nord Lead A1
DSI Mopho X4
  #25
Old 06-29-2018, 01:33 PM
PhiBee's Avatar
-dj
Yes, ordinary using keyboard for editing, but for the video I used the context menu.
  #26
Old 06-29-2018, 05:13 PM
Multiple playlists maybe?
Elastic audio enabled?
I'm just throwing things out there as it seems the next plan of attack would involve an exorcist
Jack
QAPLA!
  #27
Old 07-03-2018, 01:58 AM
walter rohrbach walter rohrbach is offline
I remember having the same bug a while ago.
If I remember right: Creating an empty MIDI clip right before and merging it (Shift-Option-3) with the existing one solved the problem.
walter-rohrbach.com
  #28
Old 07-03-2018, 11:34 AM
PhiBee's Avatar
Thanks, I’ll have a try.
But also waiting Avid’s answer
  #29
Old 07-03-2018, 02:25 PM
PhiBee's Avatar
Default midi bug: cannot delete one note !
Just had an answer from Avid (thanks Jeffro)
«Current Response:
Entered on: 7/3/2018 2:06 PM Entered by: Jeffro
Hey Philippe,
Thanks for sharing the session file. I was able to repro on my system so have passed the session on to Engineering.
I found that F1 gets deleted on its own if I merge its Clip with the following Clip. Merging its Clip with the previous Clip allows me to delete F1, so that might be a workaround for you for now.
Will let you know if Engineering finds a root cause
So, I'm not completely crazy ! Not bewitched either !
  #30
Old 12-28-2020, 11:28 AM
Firechild Firechild is offline
BUMP
Pro Tools Ultimate 2020.12.
Still can´t delete things from MIDI Event list.
Worked great in Pro Tools 10.
I tried consolidate MIDI regions to one long. Still can't delete.
Workaround is to delete things in the MIDI Editor window...
Please repair this Event list bug.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7
delete an earlier note cuzzzzz Getting Started 0 10-26-2015 07:09 PM
double click midi note add and delete stevedresser83 Windows 1 05-06-2011 07:35 AM
Smart Tool to delete midi note protollo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 11-12-2009 12:39 AM
can't delete a midi note !!?? monkey MIDI 7 03-28-2003 05:12 PM
