  #21
Old 01-11-2021, 11:09 AM
tvon tvon is offline
Default Re: PT 2020.12 Occasionally stopping playing - Windows update service?
So i'm going to try this again (my last message never got posted.. mods said it needed to be "reviewed"??)
I went to the computer and ran into the same issues again after running down all of Avids recommendations for Windows 10's optimizations. I also found out im not on the latest Windows 10 version. (version 2009). I ran Latency Mon when it was working fine and one when it was not. I'll post the report from the one where it did not. Also i got a message for the first time when trying to stop it from freezing/lurching:
  #22
Old 01-11-2021, 11:10 AM
here is the error report:
CONCLUSION
__________________________________________________ __________________________________________________ _____
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:00:43 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: PROTOOLS
OS version: Windows 10, 10.0, version 2009, build: 19042 (x64)
Hardware: OptiPlex 3070, Dell Inc.
CPU: GenuineIntel Intel(R) Core(TM) i5-9500 CPU @ 3.00GHz
Logical processors: 6
Processor groups: 1
RAM: 16193 MB total
CPU SPEED
Reported CPU speed: 30 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 687.0
Average measured interrupt to process latency (µs): 1.835343
Highest measured interrupt to DPC latency (µs): 685.40
Average measured interrupt to DPC latency (µs): 0.698726
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 89.338667
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0.038034
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0.041498
ISR count (execution time <250 µs): 26443
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 361.0840
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 457.07 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.137626
Driver with highest DPC total execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in DPCs (%) 0.195169
DPC count (execution time <250 µs): 141205
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 14
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: svchost.exe
Total number of hard pagefaults 347
Hard pagefault count of hardest hit process: 286
Number of processes hit: 4
PER CPU DATA
CPU 0 Interrupt cycle time (s): 0.876478
CPU 0 ISR highest execution time (µs): 89.338667
CPU 0 ISR total execution time (s): 0.107106
CPU 0 ISR count: 26443
CPU 0 DPC highest execution time (µs): 361.0840
CPU 0 DPC total execution time (s): 0.497924
CPU 0 DPC count: 138620
CPU 1 Interrupt cycle time (s): 0.106350
CPU 1 ISR highest execution time (µs): 0.0
CPU 1 ISR total execution time (s): 0.0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 11.6820
CPU 1 DPC total execution time (s): 0.001729
CPU 1 DPC count: 902
CPU 2 Interrupt cycle time (s): 0.105437
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 12.2750
CPU 2 DPC total execution time (s): 0.001203
CPU 2 DPC count: 598
CPU 3 Interrupt cycle time (s): 0.101208
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 10.6930
CPU 3 DPC total execution time (s): 0.000844
CPU 3 DPC count: 423
CPU 4 Interrupt cycle time (s): 0.09860
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 15.539667
CPU 4 DPC total execution time (s): 0.000767
CPU 4 DPC count: 317
CPU 5 Interrupt cycle time (s): 0.108701
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 151.754333
CPU 5 DPC total execution time (s): 0.001257
CPU 5 DPC count: 359
  #23
Old 01-11-2021, 11:12 AM
looks the mods will not approve any reports i post. so heres an image of it::
  #24
Old 01-12-2021, 03:12 PM
It shows you ran it for 43 seconds. I would say let it run 10 minutes minimum.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 9900k
Win 10
  #25
Old 01-12-2021, 07:42 PM
Should i run it before theres an issue or when there is?
  #26
Old 01-13-2021, 11:15 AM
The Weed's Avatar
The Weed The Weed is offline
Close any programs and run LatencyMon for 10 to 20 minutes. It doesn't depend on an issue with Pro Tools, but rather will highlight any issue with real-time audio.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
  #27
Old 01-15-2021, 07:53 PM
done! (sorry about the images, board blocks posts that have the full text in it)
  #28
Old 01-16-2021, 11:58 AM
The Weed's Avatar
Looks like it's your video card's driver. Always get the updated driver from the manufacturer's website, not the third party's website. For example, I have an ASUS NVidia card, but get my drivers from NVidia's website, not ASUS', manually searching for the correct driver. And I only install the graphics driver and physx, nothing else.
Once you install the latest diver, or update/upgrade anything remotely connected with Pro Tools, do the Trasher Dance: Close PT, backup your Preferences, delete Preferences, Databases and Plug-in Databases, empty the Recycle Bin, reboot, Restore Preferences, start Pro Tools.
Whenever anything goes awry with PT, the first suggestion is always to delete Preferences.
SonoBus
  #29
Old 01-17-2021, 10:07 PM
Thanks for the help. I reloaded the driver from the nvidia site and not dell. Also trashed my prefs and restarted. I was using it today and it did freeze up again. Only once though, which is a first. Its usually every 15 minutes. Im going to run LatencyMon again and i'll post the results.
  #30
Old 01-19-2021, 11:58 AM
The Weed's Avatar
Look at the "Help Us Help You" link at the top of the forum and post a Sandra report. Also look at this Thread for more optimizations and this Thread for Processor Affinity.
SonoBus
1/14/2020 - Important Service Notice marianna General 0 01-14-2020 07:16 AM
Public Service re windows update albee1952 Windows 3 03-12-2018 02:57 PM
What easy fix for a session occasionally stopping from running out of CPU power? bill60532 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-27-2011 07:01 PM
Protools 8.0.5 update stopping (downloading that is) Hotcrazyfruit General Discussion 1 05-16-2011 06:33 PM
Itunes 7.4.1 update stopping Pro tools from opening martyk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-21-2007 05:00 PM
