Old 06-14-2010, 06:41 AM
RogTaylor RogTaylor is offline
Default Problems recording midi (Korg SP-250)
I am new to pro tools. When I try to record my Korg SP-250 I can see that pro tools register the instrument. When I press down the keys I see the sound bar moving, and that pro tools record what I play. But I hear no sound. Why is this? Do I need some kind of plug ins for my actual instrument?
Help please :)
Old 06-14-2010, 06:50 AM
nst7 nst7 is offline
Default Re: Problems recording midi (Korg SP-250)
Do you have audio cables hooked up to your Protools interface? If not, you will need to do that, then create an audio track and set the inputs to match, then record arm that track.
Old 06-14-2010, 07:02 AM
This is a good place to use a stereo INSTRUMENT track. An INSTRUMENT track combines a MIDI track, with an AUX track so you can keep the session smaller and more tidy. It prints the midi info from the keyboard(midi has no sound, BTW) and you can either select the audio input, and use the Korg as your sound source, or insert an instrument plugin in the top insert slot for your sound source(something like MiniGrand for piano, or DB33 for organ). Instrument tracks can be a bit confusing at first. If you view the MIX window, and go to the top menu bar and hit VIEW>Mix Window Shows>>> there is an option to view Instrument. What that is, is a new row at the very top of the MIX window that actually is showing the midi input "instrument"(by default it will show ALL as it will receive midi on all midi channels). It is possible(with the correct settings) to use multiple midi devices(like 2 keyboards at the same time for different instrument sounds). anyway, you can see why it can get confusing. Start slow and keep it simple at first.
Old 06-14-2010, 10:00 AM
Hey! I only use a this cable: http://smartpenguins.com/fastpenguin...ex-listing.jpg
Its called Edirol UM-1ex.
Old 06-14-2010, 10:08 AM
scenicrecords scenicrecords is offline
That is only the MIDI interface. MIDI is only data. You will need to route the Audio from your keyboard back into Pro Tools or a Mixer (however you are monitoring).
Check with headphones connected to your keyboard. Then connect your audio outs into PT, and set up like Albee said.
Dell Studio 1555 Laptop, Intel Core Duo T6600 2.2GHz, 4GB RAM
Windows 7 64-bit
Pro Tools M-Powered 8.0.4cs2
M-Audio Firewire 410 via Digi-Qualified SIIG FireWire 2-Port ExpressCard {NN-EC2012-S1}
Glyph 050Q 500GB via eSATA
Old 06-14-2010, 10:18 AM
So I connect an audio cable in the "DI" input on my mbox to my keyboard. I will have to try that then.
MIDI recording w/Korg PA500 in pt 8.05 le yellow Eleven Rack 2 04-30-2012 05:53 PM
recording MIDI from Korg 01/Wfd to PT7.3 no go EricWillhelm MIDI 0 02-06-2007 09:34 AM
Recording MIDI into Pro Tools from Korg Triton Sean1212 Tips & Tricks 3 07-30-2005 07:40 AM
HELP!!! KORG TRITONLE/001 MIDI PROBLEMS philipo MIDI 2 11-07-2002 11:57 AM
Korg Oasys Midi Problems rseely MIDI 10 05-19-2001 07:39 AM
