MPC 2000/MIDI Beat Clock issue
I am using PTLE 6.1.1. I am using the Midi Beat Clock to sync my MPC2000. I am using the MPC to trigger PlugSound Drums&Percussion. So I basically recorded a drum track on my MPC and want to dump it to PT. I then open a audio track assigned to BUS 1 and the AUX track from the PlugSound output to BUS 1. I am basically recording the MIDI and AUDIO at the same time. However when it starts recording there is a latancy. Is there any type of MIDI offset? Remember I am starting on track 1. I also set the Shift Early on the mpc to several ms and still having the same problem. Your help will be greatly appreciated.
Re: MPC 2000/MIDI Beat Clock issue
make an extra 2 bars of emptiness on the MP's sequence so it has time 2 catch-up. u should b good with this.
Is there any way to do this on PTLE? I usually use sequence mode on the MPC.
Does anyone else use an MPC that can help me?
MPC 3000 and PT 9 beat clock issue | michaelc22 | macOS | 0 | 10-03-2011 10:24 PM |
MIDI beat clock latency issue!! | overseasmusician | Pro Tools M-Powered (Win) | 0 | 11-04-2007 04:57 PM |
Syncing an MPC 2000 to PT LE 002 with MIDI Clock | jdeville | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-03-2007 07:10 PM |
MIDI BEAT CLOCK ISSUE | atomsmasher | Pro Tools TDM Systems (Mac) | 1 | 12-04-2006 05:56 PM |
Triton...is MIDI Clock difrnt than MIDI Beat Clock | BookSix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-12-2006 12:24 AM |
