Old 01-12-2018, 02:01 PM
robertg robertg is offline
Default Message for Eddie Jones
Hey Eddie. I look forward to your response regarding Logic Pro X bugs.
I realize that Pro Tools is your priority and that making competing DAWs work 100% with EuCon is less so.
There are some very very very old Logic X related bugs that deserve a little attention. In addition to that, Apple has made recent changes such as increasing the bus count to 256, this has screwed some things up in the PT Control iPad App which I also use.
I have invested into 5 of these control surfaces going back to the MC days, by the way.
A comprehensive review of all Logic X <> EuCon functionality would be nice. Is that in the realm of possibility??
thanks in advance
Old 01-12-2018, 04:33 PM
EddieJones's Avatar
Default Re: Message for Eddie Jones
We do review each DAW every release, but a lot of the time have to rely on the DAW manufacture (who write the EUCON into their code) to fix bugs.
Is there anything specific other than what you say about the large track count (which I'll ask someone to look at)?
Old 01-12-2018, 07:37 PM
Yes sir, there are two longstanding Logic X bugs. One is that EuCon surfaces show some extra text when you try to insert a plugin from them. For example where it's supposed to say "Amps" it says "z001Amps".. "Delay" is "z002Dela" etc. I've attached a picture for reference.
The second is that sometimes plugin names show up completely blank on the surfaces. You can turn them off and on with the buttons, and go into edit mode, but with a lot of plugins on in a large session it's impossible to tell what you are affecting.
thanks
Old 01-13-2018, 12:43 PM
Eddie, I wanted to give you more detail about how the PT Control app is misbehaving for Logic:
These all apply to channel mode
1. Input page (audio tracks), the center section shows a single page with bus 254-256 but the 8 choices are completely different, there should be multiple pages here which correspond to every possible input and bus available.
2. Output page (audio tracks) has the same problems as input. I believe the additional busses added by Apple messed this all up.
3. Input page (software instruments) is blank. Is there supposed to be a selection of AU instruments to choose here?
thanks again
Old 01-13-2018, 10:53 PM
One more old Logic X bug for the list.
Plugins that are opened from the EuCon surfaces frequently close immediately and need to be re-opened.
Old 01-16-2018, 11:28 AM
EddieJones's Avatar
I played with Logic 10.3.3 for a bit this morning.
The plugin names not showing up is an old bug and we know about that and Apple have been informed.
I can't reproduce the funny char that proceed names though ?
Can you say what is going on with the high track counts and the Control App. I was running over 400 tracks (inc Inst) and whilst it took a while to add the Instrument tracks, after that it was working as expected ?
Old 01-16-2018, 01:35 PM
If you can't reproduce, I'm going to try clearing my XML files in case it's something related to my eucon key customizations
The PT control related bugs aren't with high track counts, I was only working with one track, but what is selectable on input and output is not right, I'll send you more detail and screenshots later
Old 01-16-2018, 06:04 PM
Hey Eddie, I've just tried this on a system that has never had Eucon on it before and the bug is here too. Can we make sure you are trying to reproduce it the following way?
Logic > New Project. Create one instrument track
Go to eucon controller, inserts, config mode
choose insert 1
There you should see the choices.. No Plug, Recent, etc.. and if you scroll right the bugged category names appear. z000Amps, z001Dela, z002Drtn, z003Dnmc.
This is on an MC Mix
Here are my versions for this system if that helps.
OS X 10.12.6
Logic Pro X 10.3.3
EuControl 3.7.0 138
Thanks
Old 01-22-2018, 09:46 PM
Eddie, any luck with this? I'd hate for this issue to not be investigated thoroughly. Can you ask your team to check it out?
Thanks
Old 01-23-2018, 07:12 AM
EddieJones's Avatar
I want to check this out myself but wont be in front of a system with Logic till Wednesday.
Eddie Jones, of Avid: My Hero WildHoney Pro Tools | S6 5 09-30-2017 09:16 AM
Free Eddie Kramer Signature Series Guitar plug-in + Win a Free Mix from Eddie Kramer unkJE AAX Plug-ins 2 01-09-2015 03:50 PM
RIP George Jones mjslakeridge General Discussion 5 05-02-2013 09:53 PM
Norah Jones CD: Come away with me iamstudios General Discussion 15 02-26-2003 04:00 AM
Jones'ing for a MicroLynx fakshen Post - Surround - Video 4 11-28-2002 08:40 AM
