why doesn't "control/click" work on midi regions?
pro tools 8 LE on a mac with 10.5.8.
indeed, I've attempted the "control click" method while moving a midi region so that it is anchored to the insertion point as you move it vertically up and down in the edit window. Since this is old hat with audio regions, one would expect to be able to do the same with midi regions. however, it doesn't work. instead when control clicking a midi region it switches from region view to note view. please fix this in the next PT 8 update. cheers! AL |
Re: why doesn't "control/click" work on midi regions?
OSX10.6.8, 1st gen Power Mac, PT8.0.5, Mbox2 |
well...c'mon...if it's control click that works with audio regions then it should work for ALL regions.
digidesign can simply come up with a different key command for the feature that you've been enjoying. control click IS taken. |
"Tuner" and internal "DSP" doesn't work on Mbox 3 Pro | luckydjacks | FireWire & USB Audio Interfaces (Win) | 129 | 06-20-2014 03:25 AM |
Does "swipe comping" work for MIDI tracks, or only audio? | yeloop | Pro Tools 11 | 2 | 07-24-2013 04:52 AM |
Does the app "Easy MIDI" work in Pro Tools? CAPS-LOCK Keyboard | aasteveo | Pro Tools 9 | 3 | 02-10-2013 10:19 AM |
Toggle Track view ("Opt"+"-") doesn't work | LukeFromBerlin | macOS | 3 | 04-01-2012 04:43 AM |
If I "Remove Unused Regions" after "Consolidate", track won't play? | el biciclista | Pro Tools TDM Systems (Mac) | 10 | 04-02-2003 10:17 AM |
