Old 11-16-2017, 05:47 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Default MIDI Notes deleting when a tangent region is deleted
This is an odd issue with MIDI editing in PT (I'm on PT 12.8 - Win 10).
So, I had a MIDI track with notes programmed, and I wanted to divide them into separate regions on the grid. Basically, I had 8 measures of whole notes, with exactly one measure in between each note. Everything was done on the grid. So I separated the MIDI region on the grid, and then I wanted to delete the empty regions, basically measure 2,4,6, 8 etc. But, when I selected and deleted measure 2, the note in measure 3 disappeared too. Same for measure 4, with note in 5 disappearing. I used the trimmer tool to make sure everything was spot on the grid, and it was. But no difference. This has to be a bug in PT MIDI functioning.
Has this happened to anyone else?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 11-17-2017, 12:31 AM
Stig Eliassen's Avatar
Default Re: MIDI Notes deleting when a tangent region is deleted
Yes, I've seen it happen a few times. It can also happen when you duplicate a clip. I think it has to do with sample rounding. Very annoying indeed.
Old 11-17-2017, 05:05 AM
DonaldM's Avatar
Thanks, Stig. At least it’s not just me!!
Old 12-26-2017, 03:51 PM
SAM CA SAM CA is offline
I keep forgetting about this VERY annoying problem and my notes go missing when I edit this way. It's beyond annoying if you have a thick arrangement, so you lose more than a single hi-hat or something.
Old 01-07-2018, 05:44 PM
DonaldM's Avatar
Yes, that would be very annoying! Seems like this bug should be fixed pronto as many have reported having the issue!
Quantize Midi - deleting notes Matt Darcy Pro Tools 11 0 04-17-2015 01:49 PM
midi regions and deleting notes Shatzer Pro Tools M-Powered (Win) 22 10-25-2011 01:26 AM
Deleting hidden midi notes jonah day 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-25-2006 10:54 AM
Deleting MIDI double notes... Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-17-2006 07:07 AM
Deleting/Copy MIDI notes is not deleting/copying MIDI sustain? Mark_Knecht 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2002 12:29 AM
