Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 05-23-2017, 01:08 PM
jimst57 jimst57 is offline
Default Automation And Volume Control
Something I can't sort out......
Let's say I bus all my music tracks to a stereo Aux track and call it Music. Simple enough.
I did this because I have a lot of volume automation on several tracks and that makes it hard to change volume levels. This way I thought I could just raise or lower the Music stereo Aux fader to control the overall level of the music and not lose the automation. It works. But what about the Aux tracks I have with reverb and delay on them? Many of my tracks have sends on them to those Aux tracks. So the question is, would I have to raise or lower those also if I touch the Music Aux fader?
Hope this makes some sense.
Old 05-23-2017, 01:43 PM
Drew Mazurek's Avatar
Default Re: Automation And Volume Control
make a group for the tracks you need to adjust, make a VCA and assign it to that group. Pull down the VCA as needed, then right click on the VCA master and choose coalesce automation. Done.
www.drewmazurek.com
Old 05-23-2017, 03:22 PM
Thanks. I'll give that a try.
Old 07-17-2017, 07:58 AM
Bunty312 Bunty312 is offline
Route the reverb and delay tracks to the Music Aux fader..? If you don't use the same reverb and delay tracks for other things that is..
Sent from my Redmi Note 3 using Tapatalk
Precision control with volume automation hrocks Pro Tools 12 1 04-13-2016 05:00 PM
PT7 LE Digi003 midi control audio volume automation juanmaortega 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-12-2015 09:58 PM
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
FCP, OMF & volume automation idris Post - Surround - Video 9 09-03-2010 08:06 AM
volume automation and a control surface (BCF2000) Chief Pronto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-08-2009 12:34 AM
