Listenback/Talkback. Auto sending an tone when recording.
I'm looking to create an automatic listenback solution so that I can listen to whomever is recording while they are in between takes. From what I've read, a popular method was to take a SMPTE timecode and key a compressor or gate. This would auto mute a microphone when recording.
While I don't have a SyncIO (and can't generate an SMPTE timecode) I was wondering if I can generate a tone from the Signal Generator plugin just when recording (not playing, or just record enabled). So I guess I'm asking if someone knows how to automatically send a tone out through a channel only when recording. Any other suggestions that would tackle this problem would also be helpful. Thanks, Wm Schwartz |
Re: Listenback/Talkback. Auto sending an tone when recording.
Make a selection on a new track - for the length of the track or region you plan to record -- use the Signal Generator Audio Suite plug-in and create a region of tone... use that for your gate trigger.
Rail
At the risk of sounding dense, are you suggesting that I pre-record the tone ("create a region of tone") for the length of the track/region that I plan to record?
Wm |
Yes - that's the way we would have had SMPTE on track 24 on an analog reel. Now when you hit play - the tone plays back, when you hit stop it doesn't.. use that to open/close/duck your talkback.
Rail
Rail, thanks for your help. I'll give it a try.
Wm |
Source Talkback AAX gets auto talkback | MIKEROPHONICS | Post - Surround - Video | 0 | 11-20-2013 08:15 AM |
Sending -20db 1Khz tone... meter shows -3db??? | tomloud | Post - Surround - Video | 11 | 08-14-2006 11:56 AM |
Auto Talkback | Archmart | General Discussion | 3 | 03-04-2006 10:23 PM |
C24 Listenback and talkback problem | RCKPROD | ICON & C|24 | 0 | 11-29-2004 12:07 PM |
Listenback / Talkback problem | Mano | ProControl, Control|24, Command|8 | 4 | 04-24-2001 11:57 PM |
