Plugin installer?
If and when I accidently delete a plugin or plugins, which can happen sometimes, I have read advice here that they can be re installed by using the installer feature. Pardon my ignorance but how do I find the plug in installer and how do I use it ? Advice please. Thanks.
Re: Pugin istaller?
Re: Pugin istaller?
Thanks musicman691. I'm referring to Pro Tools RTAS and third party. I'm on Pro Tools 9, Win 7, 32 bit. The plugins were deleted when I trashed preferences by following instructions from a You tube video. Unfortunately some of my plugins were in the DAE folder which was deleted! I have since found that the DAE folder contains a sub folder and, according to Sweetwater tech support, is the folder that I should have deleted! Now I find that the sub folder, DAE prefs., also contains some plugins! What I need is for someone to explain this conundrum and hopefully tell me how to solve it.
Re: Pugin istaller?
Re: Pugin istaller?
This is why you can never give too much info when asking a question. Sorry I can't help you with this. ???
musicman691, I'm confused by this reply! I think I supplied all the information that I have at my disposal. Please elaborate. Thanks |
Re: Pugin istaller?
Your initial post left a lot unknown which was later given in your second post. What I was trying to get at was if you had written in your initial post what you had in your second then a better answer could be given. You gave NO info on what plugins or circumstances this happened on initially. No system info, PT version, etc.
Re: Pugin istaller?
For the individual plug-ins that you purchased or own, check here: Audio Plug-ins Finder at www.avid.com/plugins Go to the individual product pages, and you should find the RTAS version installers at the bottom of each product. |
Re: Pugin istaller?
Sorry musicman691. I know that sometimes we learners try the patience of you pros but it's unintentional. Knowing the right questions to ask is a good rule to go by but knowing how to ask those questions is still a matter of how much a person already knows! In my case that is the reason I didn't supply adequate info for you to supply adequate solutions.
I'll try to fill in the blanks the more I learn. Thanks |
Re: Pugin istaller?
Eleven TDM plugin installer? | lownotesinc | Getting Started | 2 | 11-16-2013 11:12 PM |
v control (v2) plugin encoder cannot instantiate plugin screen in PT10.0.1 | klyg | Artist Series | 2 | 02-29-2012 10:50 PM |
The installer was unable to launch the PACE system files installer - Help please | buzz302 | Pro Tools M-Powered (Win) | 3 | 02-14-2012 09:05 AM |
Is there a seperate Windows 7 64 PT 8 installer (other than WinXP installer) | RuffinMedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-26-2010 09:43 PM |
ProTools Installer/Un-Installer Bug? | thias | Pro Tools TDM Systems (Mac) | 1 | 09-18-2006 08:12 AM |
