Old 03-15-2011, 09:47 PM
emmen emmen is offline
Default Factory 003 and Playback Engines
I am using my Yamaha Motif XS 8 workstation as my Playback Engine and want to continue using the Factory 003 as a control surface and a MIDI device.
IF I switch the Engine to the 003 and then to the Yamaha, the 003 continues to function after this (except for the I/O, of course). However, next time I load PT the 003 is dead in the water unless I toggle the Playback Engine again. It seems that there is some 'initialization' sequence that needs to happen once to get the 003 working. After that, it doesn't care who's running the Engine.
It's just inconvenient to have to mess with the audio engine every time I launch PT, especially because all the MIDI devices seem to lose their I/O assignments every time the engine changes.
Any ideas on how to avoid this? Obviously the 003 is capable of working as a control surface while not the Playback Engine - once it has been kickstarted.
All input would be very helpful...
Thank you,
emmen
Dell Inspiron 530
Win 7 64bit
Factory 003 and/or Yamaha Motif XS8 Workstation
Pro Tools 9.02
Old 03-16-2011, 07:10 AM
Default Re: Factory 003 and Playback Engines
Many of us are hoping for a firmware update that will allow the 003 to be used as a controller only(so we can use it with HD/Native or with an interface that has more IO). I am confused on why you would prefer to use the Yamaha for IO here. What is the advantage?
Old 03-16-2011, 07:30 PM
With the Yamaha as the playback engine I get 16 digital outputs from the synth to Pro Tools (huge for me because I'm a keyboard guy), separate stereo and phones outputs from Pro Tools, and two channels of Mic/Line input.
So long as I do the little dance to get the 003 initialized correctly, I still can use the 003 as a control surface. The only thing I lose is the 8 channels of simultaneous analog input. But, 99% of the time I only ever need a single mic input.
I do hope that digi will release a driver that allows the 003 to 'boot' properly even when not the Playback Engine. Or better yet, figure out a way to support aggregate inputs.
Dell Inspiron 530
Win 7 64bit
Pro Tools 9.02
Removing Playback Engines from list of choices bcwiz Windows 0 10-08-2012 08:19 AM
Removing Playback Engines from list of choices GordonFreeman macOS 1 10-08-2012 06:03 AM
Mbox 3 disappeared from playback engines LaS Windows 0 05-10-2012 04:15 PM
Replacement Jet Engines Pirate Post Aspera DigiDelivery 1 09-16-2011 05:14 PM
playback engines jimlongo Pro Tools TDM Systems (Mac) 0 06-21-2006 10:59 AM
