Old 07-09-2018, 03:28 PM
Diosan Diosan is offline
Default AAF from Media Composer error, "media file's location"
Hello everyone! Any news on this error?
"Could not complete the Import Tracks command because an unexpected error happened while trying to find a media file's location"
It was supposedly dealt with in the release notes for Pro Tools 11.3.2 (I'm on PT v12.3)? I've tried exporting the (v8.4.3) Media Composer's AAF's using linking, consolidating, and even transforming sample rate, bit depth and file format. No Luck. Any thoughts/experiences with this one? I've seen other posts on this error and none of them have been able to internally solve the issue.
Old 07-09-2018, 03:58 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
Default Re: AAF from Media Composer error, "media file's location"
How big is the AAF? Is the AAF export audio only?
If audio only and less than 2GB's you could try embedding the media in the MC AAF export. I have never had an issue using audio only MC AAF's exports with embedded media.
Andrew
Old 07-10-2018, 07:39 AM
Hello, If I embed, which I usually don't, it's about 800mb. I usually link and don't embed (same system) but both methods are producing the same error with 3 MC aaf's out of 14. All the media is stored in the same place and is not offline in Media Composer.
Model : HP Z840 Workstation 103C_53335X G=D
Serial Number : 2UA53*****
Chassis : HP Mini Tower
Mainboard : HP 2129
BIOS : HP M60 v01.58 06/09/2015
TPM - Trusted Platform Module : IFX 1.2 (PCR 24)
Intel vPro : 9.1.25.1005
NUMA Support : 2 Unit(s)
Total Memory : 64GB ECC DIMM DDR4
Old 07-10-2018, 08:21 AM
philper philper is offline
Are you sure it is a PT issue, and not a settings issue in the export from MC? I've opened a whole lot of AAFs in PT 3 thru 12 and have never seen that error. Also, the AAF can be bigger than 2 GB--that limitation ias an aspect of OMF, not AAF.
Old 07-10-2018, 08:55 AM
Yes, I'm aware that aaf does not have that limitation, just answering the previous poster. I've made identical aafs from similar projects on the same drive in the past 2 weeks and used the link-to setting. 3 projects produce this error, I'm at wit's end, I tried sending the aaf (media embedded) to another PT system (same specs, different computer) same error.
Mainboard : HP 2129
Old 07-10-2018, 02:21 PM
Reckless Erik Reckless Erik is offline
Mixed sample rates/video rates in the original aaf?
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 07-10-2018, 02:42 PM
Yes, sample rate all 48Khz but the show is 99% 23.98 and 8 b-roll clips at 29.97. However, to be honest, every other timeline that worked had similar uses of 29.97 in a 23.98 project, in fact, the intro in every episode has 29.97 and 59.94 and they all worked.
Mainboard : HP 2129
Old 07-10-2018, 03:10 PM
On second look, the aaf is all 23.98, everything audio is the correct frame rate and sample rate, b-roll has nothing to do with it in this case, 29.97 or not.
Mainboard : HP 2129
HTML code is On
Media Composer AAF clips referencing incorrect section of media David McCarthy Post - Surround - Video 13 03-30-2017 12:11 AM
Media Composer 5.5 (avid) export of AAF file gives NO HANDLES on audio files SplinterMathwood Post - Surround - Video 1 02-28-2012 05:52 PM
"this session contains media that is not supported by the video peripheral" samplaire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 08-25-2011 10:42 AM
MXF AND MEDIA COMPOSER BINS - file sorting and export MIKEROPHONICS Post - Surround - Video 28 10-21-2010 02:22 PM
Import video PT 8.0.3 on SL : "Invalid video media file" obahamas Pro Tools TDM Systems (Mac) 3 01-07-2010 06:13 PM
