Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 05-14-2018, 10:38 PM
Tsen Ru Tsen Ru is offline
Default Transpose single midi drum note
I have a midi drum loop recorded on a single track and would like to understand if there is an easy way to transpose a single midi snare hit to a different key. Ideally i'd like to do this without breaking the midi drum components into separate tracks. Any suggestions?
This is in pro tools 12
Old 05-14-2018, 10:58 PM
Stig Eliassen's Avatar
Default Re: Transpose single midi drum note
In the MIDI Editor, click the wanted key in the vertical keyboard on the left. All notes for that pitch will be selected.
Then press Alt+T to transpose, or shift+drag the selected notes.
Rendering FX on a single MIDI note adam79 Virtual Instruments 5 11-05-2017 02:19 PM
Problem with single-note MIDI view 11.2.1 yonkiman Pro Tools 11 3 06-16-2015 02:30 PM
Entering Single MIDI Note With Trigger JCWarrior MIDI 1 06-02-2009 11:30 AM
can we detune a single midi note in PT 7.3? siga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-31-2007 10:27 AM
Single Note View MIDI e-rase 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-11-2006 06:46 AM
