Old 05-08-2019, 12:29 PM
dbo dbo is offline
Default Soft Keys/Macros for rendering Audio Suite
I am trying to program a soft key/macro to render AudioSuite plugins to a selected clip, for example:
--Render user default 'Normalize' setting to selected audio clip (in my case that's set to -12dB, peak)
or
--Render 'Reverse' selected audio clip
Does anyone know how to do this, or a workaround?
Thanks
Old 05-08-2019, 12:36 PM
dbo dbo is offline
or
Thanks
Old 05-08-2019, 05:41 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Soft Keys/Macros for rendering Audio Suite
Mac;
System Pref's >Keyboard>Shortcuts (Add Pro Tools)
i.e.
Shift F13 = Reverse
Shift F14 = DVerb
etc...
Old 05-09-2019, 07:56 AM
Personally I do this with Keyboard Maestro and have macros for sending to RX7 and rendering (amongst others). As suggested above you can program a key command through the OS, but I don't think you'll be able to program the "render" button through that.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 05-09-2019, 11:58 AM
Richard901 Richard901 is online now
I use Keyboard Maestro ($36 - Mac Only).
A trial is available at:
https://www.keyboardmaestro.com/main/
I've set up a couple of macros for Normalize and Reverse.
Pause
The pause command allows time for the AudioSuite Window to open. You can lengthen/shorten the delay.
To automatically open the Normalize window with your preferred setting
1. Set up Normalize with your settings.
2. Save a preset.
3. Set the preset as User Default.
4. Settings Preferences/Set Plug-In Default to/User Setting
dbo - Unfortunately, I don't think zip files can be posted on this forum.
If you want to send me a private message with your email address, I can send the macros to you.
They can be imported into Keyboard Maestro.
Pro Tools 2023.9
Ventura 13.6
Old 07-19-2019, 02:08 PM
John Roberts John Roberts is offline
Hi Richard,
This is very Cool! I have been struggling with KM and Apple Script trying to figure out how to do this!! I copied your macro into Key Meastro here and still can't get it to work. Reverse opens in audio suite but the render button just wont press. Would you have any macros you could share as an import? I really want to learn to do this but the curve is steep. thanks in advance, John
PS: do you have any tips for muteomatic macros? I'd love to macro a key for momentarily opening the talkback gate. essentially making a hotkey function as a talkback button.
thanks in advance for you insight,
John
Old 07-19-2019, 02:54 PM
Originally Posted by John Roberts View Post
Hi Richard,
John
Hi John - Unfortunately, I don't think zip files can be posted on this forum.
I'll have a go at a talkback gate macro.
Pro Tools 2023.9
Ventura 13.6
Old 07-25-2019, 10:40 AM
My first attempt at a Muteomatic Toggle macro held the left click in the middle of the Muteomatic circle. This worked, but the held click stopped working as soon as the mouse was moved - even a tiny movement.
My second attempt simply clicks the Play and Stop icons. I think this does what you want, but I don't have the equipment to set up a Talkback channel, so I can't fully test it.
The macro uses the "Click at found image" command, using screen shots of the Play and Stop icons.
I originally used the complete icons (with the surrounding circles), but this confused the macro - sometimes the Stop icon was clicked instead of the Play icon. I don't know why this happened - I never seen the problem before.
Pro Tools 2023.9
Ventura 13.6
Old 07-26-2019, 02:20 PM
Oliver M Oliver M is offline
The AppleScript code looks familiar. 😉
Pause
You can use AppleScript to wait for the AudioSuite window to open. Much more reliable.
Old 07-27-2019, 01:11 AM
I'm not an expert at AppleScript - I use Google to search for websites and posts on forums about how to use AppleScript. I then try to modify the scripts.
Sorry if my screenshots contain your original work. I will delete them if you want.
Great!!! Can you post a screenshot of how to do this?
Pro Tools 2023.9
Ventura 13.6
How to Adress Function Keys >F12 from the S6 (Soft Keys) innenhofstudios Avid S4/S6 3 05-08-2019 06:34 AM
Soft Keys spoons Avid S1, S3, Dock and Control App 13 10-21-2016 07:37 AM
Why no Soft Keys on S3? jacko Avid S1, S3, Dock and Control App 15 02-09-2016 07:43 PM
Soft Key Macros BobbyDazzler Artist Series 2 11-04-2012 08:43 AM
custom "quick keys" or macros jahhn Post - Surround - Video 0 01-14-2005 06:26 PM
