Old 09-28-2016, 02:00 PM
cjpurpose cjpurpose is offline
Default Reason 8.1 not showing up in Pro tools 10.3.8
I have been running Reason 8.1 with Pro tools 10.3.8 for over a year now and everything was running efficiently and smoothly until last week.I remember opening up a ableton session that i never used or opened before. It asked for many things I did not have. was just curios to see if it would open. I opened up a Pro tools session in10 and Reason 8 is missing in the Plug ins folder. tried many things(trashed "installedaaxplugins", trashed reason preferences, trashed dae preferences, reinstalled reason 8.1. re installed, Pro tools 10.3.8) to date to remedy the situation to no avail. Need real help.
I have Pro tools 10.3.8 and Pro Tools 12.4 OS 10.9.3 and Mbox 3, Mbox 2 Pro.
Old 09-28-2016, 02:20 PM
Top Jimmy's Avatar
I wonder if Reason got switched to 64 bit. Follow the directions in the link I post to put Reason in 32 bit mode. Run Reason as standalone, then quit Reason and run Pro Tools. See if your problem is fixed.
https://www.propellerheads.se/suppor...c-os-x-system/
James Cadwallader
Old 09-28-2016, 04:17 PM
Default Re: Reason 8.1 not showing up in Pro tools 10.3.8
Thanks for responding. I tried that, to no avail. I did reinstall reason and Pro tools 10.3.8. I was told that maybe it's the sequence that I did the reinstall. I should re install pro tools then reason. Any thoughts...
Old 09-28-2016, 04:25 PM
Top Jimmy's Avatar
Did you trash all the prefs? Follow the instructions for PT10 and then start Pro Tools. It will have to recache all plugins and rewire instruments.
http://www.sweetwater.com/sweetcare/...s-preferences/
James Cadwallader
Old 09-28-2016, 04:40 PM
Will try that. I found this page earlier but i could not find the "com.avid.ProTools.plist". will give it another search now.
Old 09-28-2016, 04:46 PM
Just followed those directions. Still the same result.
Old 09-28-2016, 06:29 PM
Still need help on this issue. Anyone out here that has experienced similar issue and found the answer...
Old 09-28-2016, 06:33 PM
Top Jimmy's Avatar
You may need to go to Propellerhead on this one. I know how to do the registry edit on Windows to fix Rewire issues, but I don't know how to do it on Mac OS. I think it requires editing a plist file but don't know what or where.
James Cadwallader
Old 09-29-2016, 12:27 AM
Thanks for your efforts. Appreciate it.
Old 03-02-2018, 08:17 AM
fork-media fork-media is offline
did u get this solved?
just bit me. have uninstalled as per sweet water once..
then installed 10.3.10
still the same missing...
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
Reason 8 ReWire not showing up in Pro Tools 11 maxgain macOS 6 03-29-2016 09:15 PM
reason 3 not showing up in pro tools 8 instrument list PointStudios macOS 1 10-05-2014 05:09 AM
Reason not showing the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-30-2010 06:22 AM
reason 3 not showing up as an instrument zippitydoodah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-03-2010 01:29 PM
Reason adapted not showing up Rizz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-23-2007 07:25 PM
