Old 05-01-2001, 09:09 PM
marcelloz marcelloz is offline
Default Factory presets are GONE!
As I changed the default from "factory default" to "user preset" in the Focusrite Compressor, I go to use Amp Farm and...the factory presets are gone! So I import manually, one by one, the presets from the DAE/Plugin Settings folder, but then I go to use the Reverb One and...voila`! Its factory presets are also gone.....what's happening? If I go to set my root setting folder to the one where the presets files are, nothing happens.
Thanks, I'm in pain.
Old 05-01-2001, 10:16 PM
ckevperry ckevperry is offline
Default Re: Factory presets are GONE!
Same here ....just happened this week too.
Kevin Perry
Chameleon Music
Kevin Perry
Chameleon Music
Old 05-02-2001, 02:08 PM
ckevperry,
it's good to know I'm not alone. Were you able to fix it? Importing the settings for reverb one would be long, they're in a lot of folders.
Thanks
Old 05-02-2001, 04:28 PM
nozza1 nozza1 is offline
Me too, what is happening. Was going to reinstall protools and os 9.1. Is there somrthing else happening. Date bug or something?
Old 05-02-2001, 04:59 PM
ekuehnl's Avatar
ekuehnl ekuehnl is offline
ACI/ALP Moderator
Go into any plugin.
Go to SETTINGS PREFERENCES.
Select SET ROOT SETTINGS FOLDER...
Navigate to your DAE folder and choose PLUG-IN SETTINGS.
This should reset all of your settings for all of your plugins.
YOU ONLY NEED TO DO THIS ONCE.
-Eric
Old 05-02-2001, 07:53 PM
Hi all,
I call DigiSup to figure this out, and I discovered that everytime I try to change the default from "factory default" to "user setting" in the focusrite compressor (without changing the root setting folder or anything else), the factory presets don't show up in the amp farm and in reverb one. No way to get them back, unless i trash the dae prefs and protolls prefs and restart pt having to set my preferences again.
Cool, isn't it?
EXPAND 2 - Where are my factory presets? musiclee Pro Tools 11 2 12-05-2013 08:03 AM
Factory presets for Pitchblender?? lydpik Tips & Tricks 1 06-11-2004 09:56 AM
Factory presets for Pitchblender?? lydpik Pro Tools TDM Systems (Mac) 3 06-11-2004 08:17 AM
Factory presets are gone In-G Pro Tools TDM Systems (Mac) 3 09-17-2003 07:16 PM
Factory Presets Wolfgang Eller Pro Tools TDM Systems (Mac) 4 07-08-2001 01:26 AM
