Re: 6031 error
oh, i thought you meant some new info. did these old tweaks a long time ago
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
Re: 6031 error
+1 million. but, i do again want to thank paulv and dts at least we are getting some useful info for us hd pc users
Re: 6031 error
give the user the option to decide if they want the noise or not........................... just want to make sure we're on the same page here. the noise in the recorded region makes the recording useless. why would someone want the "chose noise option"???? the pops and clicks are very very loud in the recording, you wouldn't be able to use it
Re: 6031 error - and workaround
So, prior to 8.0.1, some of these systems probably have noise and errors in their recorded audio?? Quote:
We may have found the source problem in x9blade's system and will run some more benchmarks the next few days and report back. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Re: 6031 error
Shane
#16
Re: 6031 error
Cheers, Paul Vercellotti Avid Engineering |
#17
Re: 6031 error
Could someone be so kind as to upload the dalwdm.sys 8.0 driver, that way I don't need to uninstall 8.0.1, reinstall 8.0, then reinstall 8.0.1 in order to use this fix. Thanks.
#18
Re: 6031 error
Having the same problem. For a long period I used 7.4 HD to do some post stuff at home. I converted mxf files to quick time move using AVoption|V10 and had been working at home with no problems. I moved to PT HD 8 and worked about a year with audio only not using video playback at all. After updating to 8.0.1 HD it took me again to do post using QT playback. And after a few minutes of work PT simply shut down. I was confused!!! I haven’t ever had such kind of PT crash. I want do notice that the same thing happens on another workstation with PT LE 8cs3. Usually first came the 6031 error and than PT falls. I considered it to be the problem of video compression or disc fragmentation (the file is about 40 GB) but the same file runs perfectly on the same machine with 7.4cs10 installed. So I back to 7.4 to be able to work.
#19
Re: 6031 error
i wasn't hearing seeing any pops clicks are noise on 8.0cs3 still don't as i'm using it once again . the big thing with 8.0cs3 is that if i don't purge my plugins and uncheck the check box . once in a while when i load a session it goes into massive feedback if remember and uncheck all is ok no feedback.. did find that i had autotune 5.09 installed and it wasn't qualified went back to 5.08 and autotune evo 6.09. just hadn't had the time to try 8.0.1 again...but i have my doubts that this will help !!!!!!!!!!!who knows thinking hard about just staying where i.m at and saving my money on updates riding this version and not keeping up with the lastest versions pro tools puts out as this one does pretty much all i need it to do . maybe in a few years reaper will do what i want and i can switch to that as it seems to work on about anything you install it on...
#20
Re: 6031 error
Hey paul, I am getting this in record mode. I tried the driver file swap and it still pops up.
I am running a very lean box here. all drivers updated. Any other ideas? |
Run out of CPU error 6031 | Roland Clarke | Pro Tools TDM Systems (Win) | 0 | 01-22-2013 08:41 AM |
Error -6031 | fisaac | Pro Tools TDM Systems (Win) | 19 | 04-01-2010 11:54 AM |
error -6031 | cwarrenk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-09-2009 10:39 AM |
Digi 001 - Logic Audio - (Error -6031) and the error (-10011) - Direct I/O | booyaaslam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-04-2002 01:55 AM |
DAE error -6031 | binet | Pro Tools TDM Systems (Mac) | 1 | 07-09-2000 06:59 PM |
