Pro Tools III Disk I/O SCSI Cable needed
I am putting together a PTIII system, when I discovered that I need the SCSI cable that connects the disk I/O to at least one SCSI drive. Anyone know where I can purchase one of these cables? Thanks.
Re: Pro Tools III Disk I/O SCSI Cable needed
Is this a nubus PT III system or a PCI system. I have one that I can give you if you need a PCI cable.
If you need a Nubus cable, see if you have enough room in your computer for a hard drive and use a SCSI ribbon cable to connect it internally.
If you want to know where the booze is, ask the engineer... |
You can order cables like this from tech support directly via telephone. You can find our contact information here: http://www.digidesign.com/support/ts/policy/ Thanks, Digidesign Tech Support |
Jeff, it is a PCI, You can email me at [email protected]. Put Digi in Subject line.
Digidesign, I will if Jeff doesn't! Thanks to all! |
Jeff:
Any more PCI Disk I/O to 50-pin Centronics SCSI cables??? I could use one, too. Beige G3 running PT III TDM 5.0.1 on OS 8.6. Thanks! |
The connector on the card side is called a VHDCI-50, that should help with your search.
Never tried it, but I would bet that this will work: http://www.ebay.com/itm/6-Ft-VHDCI-5...ht_1421wt_1183 If your external drive uses a centronics connector, you'd just need to get a SCSI-2 to centronics adaptor.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
The VHDCI-50 actually has 68 pins, so it is too wide to fit the connector. It isn't an actual micro-SCSI, which only has 50 pins.
If it has 68 pins, then it's a VHDCI-68. The VHDCI-68 is more common for sure, it's used on ATTO dual channel SCSI cards. But if that auction is correctly advertising the cable as VHDCI 50, that's what the disk I/O uses. Only thing I'm not sure of is the offset of the screws, but the shell of the connector could probably be swapped out if the disk i/o uses centered screws.
The 50 pin Centronics SCSI cable (HP external drives and EMU's E-4, Emax HD, SCSI connections required these also) can have both clip on wire clamps that swing over to lock and threaded screw holes 7 centimeters center to center. HP made a ton of cases with a fan for this connector. I think my cable is 3 ft. Most came with the HP case w/ 3 ft cables.
That eBAY cable is 6 ft. http://www.wegenermedia.com/ (Electrox, 86 your @ sign or beware of spammers). I do have an Opcode Studio 3 to give away, buried under a pile a spaghetti packed so tight a worm couldn't #@%! (that is if I can find it)... yes it has the OMS eprom update with a pair of more spaghetti 6 ft mac serial cables. |
I'm on the hunt for one of these as well.
Pro tools III I/O card SCSI cable | zimmy2000 | Digidesign Hardware & Software | 2 | 05-14-2006 07:29 PM |
SCSI problem on Pro Tools III Disk I/O | audiozeb | Pro Tools TDM Systems (Mac) | 3 | 04-02-2003 09:20 AM |
Is cable for 24|Mix -> 882/20 standard SCSI-2 cable? | Last Legend | Pro Tools TDM Systems (Mac) | 2 | 01-18-2003 12:36 AM |
SCSI Cable for ATTO? | johnnyd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-22-2000 08:36 PM |
WTB NuBus Disk I/O to Centronics 50 SCSI cable | Tone Sanchez | General Discussion | 0 | 06-23-1998 12:30 AM |
