AAF, not OMF from Premier :)
For all intents and purposes, OMF is (and should be) DOA. AAF is better code. And when Premier keeps making changes, Ptools suffers. And Ptools changes mess up Premier imports.
I've attached a Screen Shot of Optimal Export Settings for Premier to AAF, as well as some Best Practices to share with your Editor friends. (The result of a LOT of troubleshooting and working with my editor friends to solve issues). Enjoy! ------- Best Practice AAF exports from Premier: -Make a duplicate sequence labeled “xxxx_AAFAudio_Only”. Remove ALL clip/track based processing (EQ/compression/noise reduction). Unprocessed audio files are best for Audio Post. **EXCEPTION WOULD BE ANY TIME COMPRESSION that's been done** (we can have a separate conversation about that) -Leave fades and volume automation if you want so we know what your clients signed off on. We might change something tho :) -DELETE all video tracks from this duplicate timeline (Especially if there are Nested Sequences!! These are known AAF killers). This makes your AAF export go WAY faster. -DELETE: ANY tracks there were 'muted' in your original timeline, as that mute information doesn't transfer, and it will still include ALL of those tracks! -export the Embedded file with handles as indicated Dance with joy because your audio post peeps will be happy. :) Dave G |
Re: AAF, not OMF from Premier :)
This should be a sticky and on Premiers forums...
Until Premier/Protools changes something again.
-Mac Pro 7,1 16core 3.2GHz 96GB -OSX 12.7.2 -PTHDN 2023.12 Ultimate -HD Omni -BM Intensity Pro -Waves Mercury+SSL4000 Collection+Abbey Roads -iZotope RX10 Advanced -iZotope Post Production Suite 6 -iZotope Music Production Suite 5 -HALO UP/DOWN MIX -ANYMIX -Delonghi Perfecta ESAM 5600.S |
hmm..good idea.. Got a link to a specific forum I could check out?
Thanks DG
dg |
Also do not use Merged Clips!
When you use embedded AAF does it keep audio clip names and source timecode? I think it used to strip it, or maybe that was just with embedded OMF.
~Will |
Premier OMF Audio Distorted | subwoof | Post - Surround - Video | 3 | 10-21-2017 06:04 AM |
Sonivox Premier Upgrade | Justin1524 | AAX Plug-ins | 4 | 12-18-2016 08:56 AM |
h.264's from Premier | Dallas Taylor | Post - Surround - Video | 0 | 10-23-2011 06:03 PM |
Adobe Premier? | Ron Cook | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 24 | 01-11-2003 07:55 PM |
OMF & PREMIER | joelkaplan | Post - Surround - Video | 1 | 05-19-2002 03:00 PM |
