Old 06-01-2020, 08:10 AM
CraigLindsay CraigLindsay is offline
Default Pro Tools and hyperthreading + recommended system?
Could anyone link me to the recommended (computer) system guide for Pro Tools? I tried the "Looking for..." sticky, but the link didn't go anywhere.
In particular, I'm wanting to know how Pro Tools does with hyperthreading these days.
I recall there being issues many years ago, and I'm looking at a new Mac, however many options come with hyperthreading and it can't be turned off afaik.
Appreciate any help.
Cheers
Old 06-01-2020, 01:53 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Pro Tools and hyperthreading + recommended system?
Hyperthreading can be turned off, google for CPUsetter. But that is not permanent setting, you need to set it after every boot
Janne
Old 06-01-2020, 04:13 PM
Thank you, that's good to know. It's not too bad having to do it each when I log in to my Pro Tools user.
Does hyperthreading work well with the latest Macs or is it still a recommendation to turn it off for best results? Or is it more a "maybe", try it and see. Turn it off if it doesn't work well?
Old 06-01-2020, 04:16 PM
JFreak's Avatar
Working well on Catalina, was on/off with Mojave, didn't have problem with it before that.
Janne
Old 06-01-2020, 04:20 PM
YMMV (or YkmMV) depending on your workload and plugins. What others see may not mean anything for you, but things have improved in the last year or so with general plugin performance/scaling. Start by just using your systems without changing anything.
Old 06-01-2020, 07:21 PM
Thanks for the advice! Much appreciated!
C'mon Man!!!! (Pro Tools and Hyperthreading) roboman01 Pro Tools 2018 42 02-19-2019 01:58 PM
Recommended Hardware for a PT 8 LE system charlesd81 General Discussion 1 11-24-2010 07:30 AM
Advice on a recommended system specs please digi kingof6strings 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-15-2010 03:05 AM
Does Pro Tools LE Utilize Hyperthreading in the new Mac Pro's? Monaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-10-2009 09:15 AM
Recommended System for Mix Plus System Beatmeister Pro Tools TDM Systems (Mac) 2 07-26-2004 11:04 PM
