Old 04-24-2020, 09:44 AM
Raoul23 Raoul23 is offline
Default Meter display issue??
Today I was printing a session and have decided to print to track instead on bouncing down and I noticed a strange issues.
My sessions always have an aux track (has my mix bus plugins on) before the main out master and the levels were strange. I had a limiter as my last plugin and the levels were peaking at -0.3 on my aux track but the print track was only peaking at -3.0 even though the aux track was feeding to the print track, if that makes sense. If I bypassed the limiter the levels were the same I even tried another limiter and it was the same issue. Could anyone explain this please
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 04-26-2020, 10:45 AM
Default Re: Meter display issue??
Could it be the Pan law setting? -3 is the default but I prefer -4.5(Setup>Session>Pan Depth)
Old 04-26-2020, 01:56 PM
JFreak's Avatar
JFreak JFreak is online now
Whatever pan law you are using greatly depends on the room where you are working. In a "perfect" room you would use 6.0 but that is too extreme for most.
The default of 3.0 also assumes pretty good listening environment, which is why in the olden days PT Surround Mixer had 3.0 pan law and Stereo Mixer had 2.5 pan law. If you had HD you could switch mixers just because of pan law even if you didn't need surround. Now it is much easier. But don't overdo it
Janne
Old 04-26-2020, 02:10 PM
I don’t think so. here are some pics to help explain my problem
Raoul Crane
Old 04-26-2020, 02:15 PM
JFreak's Avatar
Levels are not matching in no-limiter pic either. Are you sure you have no plugins that might cause this?
Janne
Old 04-26-2020, 03:12 PM
Nope I’m totally stumped on this.
My sMix plugins are
AC1
Waves SSL comp
DUY Tape
Waves Pultec
H-EQ
Kush Clariphonic
Then limiter
Raoul Crane
Old 04-26-2020, 03:14 PM
JFreak's Avatar
Is it possible that there is a send that feeds something to left channel of your main outputs? Doesn't make sense otherwise
Janne
Old 04-27-2020, 12:55 PM
It was HEAT!!! I bypassed it on the print track and all is good now.
Raoul Crane
Old 04-27-2020, 01:09 PM
JFreak's Avatar
Alright, good to know
Janne
Unbalanced meter display doylemusic Pro Tools 12 7 03-27-2020 08:36 AM
5.1 meter display question amac733 Pro Tools 10 2 07-27-2016 10:34 AM
Meter display question HB1978 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-20-2009 02:44 AM
DB i/o meter display? kevinb511 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-09-2005 12:35 PM
Meter Levels Won't Display During Playback digijohn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-22-2004 01:12 PM
