Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 03-04-2020, 11:36 AM
ToneSetter ToneSetter is offline
Default Connecting preamp to compressors to interface
Which of the 2 ways below should I connect the warm audio wa73eq to a klark teknik kt2a and a klark teknik 76kt then to my interface for tracking vocals?
akg c214 into wa73eq out the wa73eq insert send into the kt2a then out the kt2a into the 76kt then out the 76kt into the insert return of the wa73eq and then finally out the wa73eq output into a channel on my interface.
or
akg c214 into wa73eq out the wa73eq output into the kt2a then out the kt2a into the 76kt then out the 76kt into a channel on my interface.
Thanks for all input
Old 03-04-2020, 11:58 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Connecting preamp to compressors to interface
I don't know that it matters either way, unless there's any noise difference between each setup.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2020.5
Old 03-04-2020, 01:50 PM
YYR123's Avatar
YYR123 YYR123 is offline
It’s kinda confusing the written way but you should be hitting the preamp first before the EQ
Mic > Preamp > EQ > Comps >
It should be like this unless you want to swap the EQ and comp position
Did I miss something?
Daniel
Old 03-04-2020, 02:20 PM
Raoul23 Raoul23 is offline
This is the best way to do it. I had nothing but issues when I tried to use the insert on my WA273EQ
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 03-04-2020, 07:23 PM
While I double-compress in a mix all the time, I would probably never do it while tracking. Its just too easy to accidentally overdo it(which can never be UNdone). I would go mic>preamp>compressor>interface. The KT2A would be my choice for vocals, but I might go with the 76 for some other sources
BUT**** the great big "but", since you never mention what interface, there is one more detail that matters. Make sure you go into the interface on a line level input and NOT a mic(XLR) input.
If you really feel compelled to go thru both compressors on the way in, I would take 2 signals(put up 2 audio tracks, make them a group, mute one, record both). 1 signal would be the output of the second compressor and the other signal would be the extra output of the first compressor(assuming they have both XLR and TRS outputs). This way, if you "overcook" with 2 comps, you also have a recording with only the first
Old 03-05-2020, 03:57 AM
musicman691 musicman691 is online now
In reference to this keep in mind that not all interfaces that have both line level and mic level inputs have separate input stages. Some use a circuit with a pad in front of the mic pre section on the line input. So you'd still be going through the mic pre circuitry.
Jack
QAPLA!
Old 03-05-2020, 01:11 PM
I understand it should go Mic > Preamp > EQ > Comps > or Mic > Preamp > Comps > EQ > but what I was wondering is if I should use the send return inserts or the output of the wa73eq to go to the comps
Old 03-05-2020, 01:13 PM
This is the way I have it now because it is less cables
Old 03-05-2020, 01:17 PM
I have a half normal patchbay so I will probably route the pre to the interface through the patchbay then also split it from the pre to the comps then to the interface on a different channel and record 2 channels. 1 without comp and 1 with just incase I'm not feeling what I did then I can just send the clean out to the comps with different settings and record back in if needed
Old 03-05-2020, 01:21 PM
I'm using the scarlett 18i20 2nd gen. If the phantom power is off on channels 5 to 8 are those line level?
Connecting an external guitar-preamp. JCcares Eleven Rack 3 05-10-2016 03:08 AM
Connecting external preamp Maddern macOS 4 12-23-2012 08:08 AM
Connecting and Setting up and external preamp lew742man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-17-2008 09:10 AM
PreAmp/Compressors daveo32 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-12-2004 06:37 PM
Connecting Preamp to Digi001 Allen Hallada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 02-21-2002 08:30 AM
