Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 03-04-2020, 09:16 AM
XJENSEN XJENSEN is offline
Default Instrument Track Commit still broken in Pro Tools 2019.12
Hi guys,
In another attempt to get a grip on this ongoing problem (re. https://duc.avid.com/showthread.php?t=387939) I did extensive further testing today.
When I listen to, commit (with/without ADC) or just old-fashionedly record an external MIDI instrument's audio, this surprisingly results in completely different amounts of delay of the recorded material.
Only the manual recording is more or less where it should be.
Delays I get when recording a MIDI snare drum (playback engine at 1024 buffer):
Commit with ADC - 2300 samples delay
Commit without ADC - 6400 samples delay
Record without ADC - 256 samples delay
So, the Commit feature seems still broken in Pro Tools 2019.12 and should not be used for recording external MIDI instruments. I really hope they will fix this some time.
Old 03-04-2020, 10:34 AM
musicman691 musicman691 is online now
Default Re: Instrument Track Commit still broken in Pro Tools 2019.12
I don't know if commit was ever meant to use with external MIDI instruments.
Jack
QAPLA!
Old 03-04-2020, 11:12 AM
daeron80 daeron80 is offline
I also am confused by the concept of committing external MIDI instruments. Seems self-contradictory.
David J. Finnamore
Nyquist was right.
PT 2020.3 Ultimate | Omni | macOS Sierra
PT 2020.3 | Saffire Pro 40 | Win10
Old 03-04-2020, 11:42 AM
Well, in the old days we only had regular MIDI tracks and would record to an Audio track, before mixing, right?
If Commit for Instrument tracks would work, this would be nice, as it can automatically copy over send and vol/pan automation.
And it kind of works, only the implementation seems flawed because of the extra delay that's showing up. I don't really have an explanation where this delay is coming from.
Old 03-04-2020, 01:31 PM
Like I said I don't think commit was made to work with external MIDI gear.
Jack
QAPLA!
Old 03-04-2020, 02:00 PM
I see not a single reason why it shouldn't work. The option is there all right.
Old 03-04-2020, 02:06 PM
cqd cqd is offline
I would think you'd have to bounce external instruments in real time..
Old 03-04-2020, 02:27 PM
Indeed. I was using the real-time commit option, which should do exactly that. But still the audio arrives out of sync. In my book, that reads like a bug...
Old 03-04-2020, 06:04 PM
Not in my book. I still submit it wasn't really designed to work with hardware synths. That it sort of works at all I'd consider gravy. And don't forget the MIDI delay that PT suffers from.
Jack
QAPLA!
Old 03-04-2020, 10:00 PM
TNM TNM is offline
Avid doesn't have an input instrument ADC like Logic and Cubase have. It's not a bug, it's just not there right now.. In C/L you have a literal thing called an external instrument plugin for this that compensates all the latency on bounce.
It *should* work with HDX though, which compensates inputs.
So.....
Maybe ask Avid, but I doubt it's even remotely a priority.
what I do is record my midi gear as audio. What's the difference? Dry audio files then I work with beautiful dry audio files to create my mix. Easy as pie.
I compose as much as I can and do very rough mixing on the go with the Apollo (monitoring fx), then record dry in one bulk 32 track run.
Of course, if you are using an interface without any of it's own DSP/Mixer that goes entirely native through pro tools, this would indeed be a nice feature.
perhaps Avid should remove the possibility from non HDX versions (maybe HDN does it properly as well though?)
EDIT: I just noticed you are on HDN, i had to click the profile which I had forgot to do prior posting, which I guess means it's a HDX only thing.
If HDX doesn't do it either then it's definitely a bug, as HDX specifically has input delay compensation.
-iMac Pro 3.2ghz 8 Core, 64GB Ram, Vega 56, OS 10.14.6/Win10 Pro, TB3 Dock & 4xSSD, UA Apollo x3 + Octopre x3, Microlite x2, Midi Synths galore, PT 2020.3
-Aorus X5 V8, 6 core Intel 8850H, 32GB ram, GTX 1070, Win 10 Pro, PT 2020.3/Nuendo 10, Apollo Twin TBolt
-Whenever I launch Pro Tools, I get wet.(™)
Komplete Kontrol Broken in 2019.5 orangepopsongs01 Pro Tools 2019 24 08-15-2019 04:44 AM
2019.5 audio suite broken [SOLVED] stanonbass Pro Tools 2019 19 05-15-2019 03:36 PM
Commit Kontakt Multi instrument yanos Pro Tools 2018 5 05-07-2018 03:00 AM
Pro Tools crashes trying to Commit an instrument track Rewired with Reason mrbenjaminspeed Pro Tools 12 4 04-30-2017 01:21 PM
Instrument Track Commit results in huge audio delay XJENSEN Pro Tools 12 23 01-13-2017 02:13 PM
