Old 01-08-2020, 12:44 PM
trevvahhh trevvahhh is offline
Default Instrument Track assigned wrong midi output when reopening sessions
Hey all - searched and couldn't find much on this. In a nutshell, sessions with multiple instrument tracks will reopen with midi outputs assigned unreliably. Normally all will open as it was saved, but often enough some instrument tracks will have their midi outputs assigned to none (instead of to the inst plugin on the track it is on and was assigned to before closing session) or assigned to a different instrument track's plugin (resulting in the midi from both inst tracks triggering the instrument on one track).
This has been happening since at least PT10, I'm at 2019.5 but don't see any indication of a fix scanning the release notes for .6.10.12 etc. Maddening for obvious reasons as i'm working on multiple sessions like this a day and trying to jump back in to address client notes without having to make sure everything is as I left it.
Occasionally seems to happen when I duplicate an instrument track more than once and then change the track order.. but not always.
Anyone with insight into this? Appreciate any input! Thanks
Old 01-08-2020, 01:04 PM
midnightrambler midnightrambler is offline
Default Re: Instrument Track assigned wrong midi output when reopening sessions
Ohhhhhhhhhhh yes...
I found a couple of reasons which I mention in this thread...
http://duc.avid.com/showthread.php?t=399759
..but who knows, there may be hundreds more by now...
Old 01-08-2020, 03:30 PM
man what a mess. just happened to me again over here. is there a best official channel to add another report on this? it's been happening forever, I know people throw a lot of criticism at avid but seems like a basic thing that needs to be addressed
appreciate your reply!
Old 01-08-2020, 10:24 PM
take77 take77 is offline
This stopped happening since I updated to 2019.12. (Windows 10)
At least in my current session which employs several instrument tracks.
I'll be starting a new session soon and will see if it happens then.
Old 01-08-2020, 11:09 PM
looks like my update plan expired two days before that release... would be great if someone else or mod could confirm that 2019.12 fixed it
thanks for the reply!!
Old 01-08-2020, 11:11 PM
Southsidemusic's Avatar
We are on Macs and never happened to us and sure doesn’t happen in either 2019.10 or 2019.12 Ultimate which is the same app as Vanilla minus some features so if it works in Ultimate it works in Vanilla too and it does.
PS. take77 is a trusted and knowledgeable contributing member here on the forum and if he says it works I would Take that (see what I did there) to the bank any day of the week
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-09-2020, 05:06 AM
I haven't seen this kind of thing since PT 11.3.2.
There are times though that PT still has problems keeping MIDI assignments straight IF you change the instrument from one vi to another say you go from EW Play engine vi to something in NI Kontakt. But once you get that straightened out it remembers the assignment forever after even if you save/quit/reopen the same session. But have not seen what the op is talking about.
Jack
QAPLA!
Old 01-09-2020, 01:42 PM
Try 2019.10. I was using .6 for a while and that's when I had resumed MIDI work and actually noticed the problem.
Then I remember saying OK I'll try .10 now and don't recall the problem since.
I had only updated to .12 to see if a whole another MIDI issue was fixed. (See sample rounding thread).
So you should have access to 2019.10 and can give that a try.
Old 01-09-2020, 01:46 PM
This may have been my actual issue since I was using NI Kontakt and various drum libraries.
I haven't changed my settings or experienced any changes since settling on a kit for the session.
Old 03-16-2020, 01:20 PM
For f*ck's sake.
For f*ck's f*cking sake.
6 mixes printed incorrectly because I had the audacity to close the session temporarily and then re-open it, leaving a random instrument track unassigned on re-opening.
SORT IT OUT AVID.
Instrument tracks won't play when reopening sessions bleen macOS 5 12-12-2014 03:01 PM
PT plays MIDI input even if not assigned to a track j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-26-2009 07:36 AM
Pro tools 7 Instrument track and MIDI sound output alkemist Pro Tools M-Powered (Win) 3 05-13-2009 10:31 PM
Midi info playing on wrong instrument track bruce lang Virtual Instruments 4 03-16-2009 07:21 PM
No MIDI output on instrument track Theorist Virtual Instruments 3 03-08-2009 09:07 PM
