Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 03-31-2018, 03:26 AM
MusicMadness MusicMadness is offline
Default Fullscreen at startup
Is there any way to set Pro Tools windows behaviour at startup? At the moment my edit window starts in window mode and my mix window starts in fullscreen. If I just click fullscreen button on edit window it goes to the left from the mix window which is opposite order that the one I have on my Command 8 buttons so what I have to do every time I run Pro Tools is bring mix window to window mode, maximise edit window and then maximise mix window again. Do you know any way to fix PT windows behaviour at startup? I know it's just a cosmetic issue but it's pretty annoying after some time.
PT HD 2018.1, Mac Pro 2013, Digidesign Command 8, Focusrite Clarett 2Pre
Old 03-31-2018, 05:00 AM
Cheesehead Cheesehead is offline
Default Re: Fullscreen at startup
I've been having this problem recently with sessions sent from another editor.
Her sessions always open with a small edit window and mix window maximised even if I drag out the windows and re-save. I don't know if its a bug with 2018, I haven't seen it before.
I tried saving new window configurations and everything but the only thing that fixed it was importing her tracks to a new template.
Let me know if you find the cure.
Mac Pro 6,1 12 core, OSX 10.14.6, HD-Native TB, Trinnov MC, 888 IO, 192 IO, Sync HD, AJA IO XT, PT Dock, PT Control, PT 2020.3
Old 04-04-2018, 09:15 AM
bump. Anyone?
Old 04-04-2018, 07:13 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Have you checked out the solutions on this thread?: http://duc.avid.com/showthread.php?t=398410
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Old 04-11-2018, 02:52 AM
Doesn't work for me, I tried a lot of combinations with that idea. I have just one screen and I want PT to open in fullscreen mode with mix window on the left in relation to edit window. That guy has 2 screens and doesn't use fullscreen mode. Does anyone know ho to set windows configuration on startup?
PT MacOS Fullscreen support clausiii Pro Tools 12 2 08-23-2015 12:15 AM
Quicktime Tips and Tricks fullscreen movie in PTLE hanzoid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-22-2003 11:25 AM
mac startup Dr. J Pro Tools TDM Systems (Mac) 2 04-16-2002 12:27 AM
Choose startup disc ---at startup???? meshtheflesh Tips & Tricks 3 12-15-2001 08:07 PM
mac startup ? can't find startup disc peterfitz Pro Tools TDM Systems (Mac) 1 03-24-2000 08:27 AM
