Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 12-08-2014, 01:33 PM
Default New Samsung 850 Evo
The Samsung 850 Pro has been ultra impressive with it's leading SATA III SSD performance but is a little bit pricy for some folks. Samsung just released a less expensive 850 Evo with slightly lower but still very impressive performance and a more affordable price point. MSRP is $500 for 1TB (around $150 less than a street price on the 850 Pro 1TB).
http://www.anandtech.com/show/8747/s...850-evo-review
The review mentions a non-released 2TB model, I'd certainly look forward to that since I can barely fit a boot/system into 1TB because of lots of developer tools and other junk but similarly for folks with large sample libraries that might be really nice.
And if you have the previous generation Samsung 840 Evo make sure you update the firmware to fix a read performance bug, and read more about that bug online, you may need to run an additional repair to restore performance.
When you install any SSD make sure it is running the latest firmware, and check periodically it is up to date, these things carry around such incredibly complex software nowadays.
All Samsung SSD software/updates are here... http://www.samsung.com/global/busine...downloads.html
Old 12-08-2014, 01:42 PM
Southsidemusic's Avatar
Default Re: New Samsung 850 Evo
Thank you adarryl for the post!
Downloading now as we have quite a few Samsung SSD's here. Where I sit right now typing I can see 6 x 850 Pro and 4 x 840 Pro and 2 x 840 EVO so time to connect them one at a time and run the updates
Damn thats a lot of dollars sitting there 70-75% filled up. Should probably move all those files to a few 2TB spinners and start re-using the SSD's for recording again instead of buying new ones, we have only used them for recording sessions and max 1 week each
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 12-08-2014, 01:48 PM
And I know you will but for everybody else, always make sure you have backups before applying firmware updates, they should be fine, but...
I would also love Samsung to get their nice SSD Magician Software onto OS X. I expect they just don't see anywhere near the demand as on Windows since so many Mac's are closed boxes.
Old 12-08-2014, 01:52 PM
Great thinking
Backup the backups as it will pay off one day when we have a double failiure.
Thanks Darryl
Christopher
PS. Do you recommend starting to buy into larger SSD's now as I read that the smaller ones were faster a while back. We have so many of them just because we always bought the 256GB ones and not the 512 or larger as I thought the smaller ones were better but I suspect that has changed since we got all these smaller 256GB drives.
Best Regards
Christopher
WEBHOME
Old 12-08-2014, 02:12 PM
Bill Denton Bill Denton is offline
@Darryl Ramm...
Have you done/seen any comparisons between the 840's and 850's or the 850 Pros vs 850 Evos?
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 12-08-2014, 02:17 PM
Originally Posted by Southsidemusic View Post
Great thinking
Thanks Darryl
Christopher
Ah generally the smaller SSDs were *not* faster in the past, they just don't have enough internal 'fan-out' of NAND flash chips to be able to deliver the same high sustained IO rates as the larger drives (and there are likely other more complex effects as well). That's why I've generally recommended avoiding the smallest two sizes of Samsung drives and I'd stick with that recommendation with the 850 Evo. You can see some of those effects in the Anadtech review of the 850 Evo, even if for many uses with Pro Tools folks won't get anywhere near the performance capabilities of these drives... and if you use timeline cache you'll likely care even less.
Old 12-08-2014, 02:22 PM
So basically it's a go to get the larger ssd's and not have to worry about any performance issues compared to the 256's we already have?
We have accumilated quite a few 256's now and it would be sweet to start using the larger 1TB SSD's even though they are more expensive at initial purchase but per GB it's a much better price.
Thanks soo much Darryl for your always very informative information
Greatly appreciated
Best Regards
Christopher
Best Regards
Christopher
WEBHOME
Originally Posted by Bill Denton View Post
@Darryl Ramm...
AFAIK nobody has an 850 Evo in the wild except it seems a few product reviewers.
I've run 830, 840 Pro, 840 Evo and played with an 850 Pro. Anandtech has all these drives reviewed and benchmarked. I just cannot fault Anadtech's reviews in any way, and they are better than I'd do in any tests (with the exception of actually running Pro Tools on the drive).
I'm needing boot disk space so the next one I'll buy can be either a 850 Pro or Evo @ 2TB, whatever they want to release first (and I expect that will be the 850 Evo as it's TLC + VNAND technology in the Evo gives them much better density than the MLC + VNAND in the Pro, but maybe there are marketing reasons to ship the higher priced/higher performing one first).
Old 12-08-2014, 02:28 PM
Greatly appreciated
Best Regards
Christopher
Absolutely. And the larger drives tend to be less of an issue with sustained write speed, and drive wear, as the same level of overprovisioning (7% by default but I'd bump to 20% for any drive being written to much) gives you a larger reserve of spare/free pages on the larger drives.
Obviously but we are talking about single drive performance comparison here. If you have a system with multiple things happening at once or if you round-robin onto the seperate smaller SSDs you may be be able to get greater performance than with a single larger SSD.
And... for folks with older Mac Pros... the internal SATA is only SATA II/3 Gbps, these modern SATA SSDs can saturate a SATA III/6 Gbps link, so stick a third party SATA III PCIe card in your Mac.
Old 12-08-2014, 02:44 PM
Super
Thank You for the great advice and great input here Darryl
Gonna order a few 1TB Samsungs and start using larger drives from now on.
Christopher
Best Regards
Christopher
WEBHOME
Have a Samsung 840 Evo? You need to read this. mesaone Windows 9 01-08-2015 07:40 PM
The NEW Samsung 850 PRO - 1TB 2.5" SSD - is anyone using it ??? Seafoam_Green General Discussion 5 08-05-2014 07:04 PM
Samsung 850 SSD Craig F General Discussion 1 07-01-2014 01:04 AM
Samsung SSD's on 3.1 MP YYR123 General Discussion 27 01-04-2013 12:03 PM
