Old 02-11-2014, 01:43 PM
johnnyz johnnyz is offline
Default Hearback Setup
Right now i have my hearback system wired to the aux sends of my console ,i could also hook up the adat optical to my hd io but i would lose the talkback ,not sure what be the best solution for the hearback system jz
Old 02-11-2014, 01:47 PM
Drew Mazurek's Avatar
Default Re: Hearback Setup
You have a few choices. One is to still have some of the hear back being fed analog (if it can do that) so you have console access and talkback still makes it through. Or, if you want to go all ITB for your sends, you'd have to add an Aux Input and route your talkback mic through PT's mixer.
www.drewmazurek.com
Old 02-12-2014, 02:39 PM
paulo m's Avatar
paulo m paulo m is offline
It´s really the user choice: either feeding it from PT or from the mixing console.
Either ADAT input or via it´s 8 analogue inputs.
When working with a console(don´t know which one you use) you probably end up using the analogue inputs of the Hub.
If fed from PT, depending on your available hardware outs, it can be either one, analogue or ADAT.
I used to feed the Hearback system from an SSL using the group busses and the console´s talkback out on one of the inputs.
For larger sessions, it was usually fed from PT itself, via SSL Alpha Link converters. In this case, using Auxes.
I mean, it´s really up to you, it depends on your workflow. The inputs are there, you know your output capability in terms of converters, just try the diferent options. You may end up using both approaches depending on your sessions. Good luck.
Regards,
Paulo M
Old 02-13-2014, 05:17 AM
Hey thanks for the replies I really liking the adat I guess I could set up a talkback mic in the control room and route it to aux track and then out to one of the optical outs of the hd io,but it is nice having the flex ability of going either digital or analog ,thanks iz
Old 02-17-2014, 07:30 AM
Had a session last nite and i was on the drums ,but was getting dropouts on the hearback mixer ,i am using the adat option on the hub gonna swap out the cat5 cable to see if that does the trick i also swap the optical cable as well jz
Old 02-17-2014, 03:01 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
I am somewhat plagued with the same issue.... I'd love to use the optical from my HD I/O, but would sacrifice the ease of my talkback setup.... since I would have to route talkback through pro tools... granted, I could save track presets in pro tools and simply mute/unmute my talkback mic, but this isn't the greatest solution
I would love it if they would add a dedicated talkback in/out to the I/O's, a footswitch jack, and add a button to the Toolbar GUI - and then add a button to my control surface :)
Then let us grab it and route it internally from the I/O Mixer
Just think! We could have a custom DB15 cable that breaks out to Talkback Mic In/Out/Footswitch..... Then the Accessory Port would finally have a purpose ! ! !
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 02-17-2014, 03:48 PM
It seems like some of the mixers have these issues.... I read some stuff about tech support walking owners through jumping a trace - due to potential trace failure.... I have not looked at one yet - but I do intend to crack one open, as I may mount one in a console (long story)
I do hear that HEAR provides awesome tech support, and have even heard of them replacing equipment at no charge, out of warranty
If you continue having issues, consider calling or emailing them
OSX Sierra
Pro Tools HD 11.2.2
Extreme Server (x2)
Live:
Win 10, OSX Sierra
LV1, MRSG
Custom enclosure
Old 02-17-2014, 03:52 PM
Craig F Craig F is offline
Other problem w/ Optical: your stuck at 44.1/48
not an issue for everyone but for some it is
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 02-17-2014, 06:03 PM
Craig... Really?
Have you ever had this?
Honestly.... never heard anyone seriously complain about the quality of a CD for standard listening (Regardless of performance)
The headphones and converters themselves (headphones mainly) would be the single biggest complaint I've seen
Never really heard about anyone complaining about in ear monitors either.... more or less the opposite....
I would be flabbergasted.... hahahha.... I really don't even know what I would say if I heard:
'hey man.... what's going on with my feed? Am I on 44,100 or 48,000 samples per second? What the crap?'
hahahahhaa.... wow.... I'd be like, 'yeah, ok, your hourly rate just increased'
OSX Sierra
Pro Tools HD 11.2.2
Extreme Server (x2)
Live:
Win 10, OSX Sierra
LV1, MRSG
Custom enclosure
Old 02-18-2014, 11:23 AM
Of the guys I know that are still doing album work for labels they are working at 96k or 192k
All I'm saying is if your working at 96k the optical option is removed from the table
Thank you,
Craig
Connecting C 24 to a Hearback headphone system pcerrato ICON & C|24 7 03-01-2011 06:15 AM
192/Control24 and Hearback System tim carter Pro Tools TDM Systems (Mac) 6 02-28-2011 01:25 PM
C24 and Hear Technologies Hearback system? jeff markham ICON & C|24 5 02-28-2011 01:24 PM
PT9 Ensemble Hearback Setup therecordinghouse macOS 0 12-21-2010 12:50 PM
002r and hearback system therecordinghouse Tips & Tricks 4 07-20-2006 09:00 AM
