Old 02-18-2013, 06:01 AM
phillyt2k phillyt2k is offline
Default Multiple ReWire for drums using Ableton and mixing them
In PT10 I have four MIDI drum tracks: Kick, snare, open hi and ride.
I have a mono aux with Ableton as an insert and it's output in the ReWire window as bus 03
In ableton I have a drum rack with samples in it going out of bus 3 of ableton's ReWire.
How can I mix these in PT? At the moment they are all just coming back in the one aux, hence the fader controls kick, snare, hi and ride all at the same time.
If I have multiple aux's doesn't this mean putting more instances of ReWire on said aux's which will cause more processing power.
Also, does that mean I will need 4 drum racks in Ableton? Which seems a bit pointless.
Is there no way to route out from the drum rack?
Hopefully that makes sense, thanks to anyone who can help
Old 02-18-2013, 07:30 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Multiple ReWire for drums using Ableton and mixing them
Read up on Routing in both Live and Pro Tools.
"Is there no way to route out from the drum rack?" Short answer is Yes.
(Help us Help You)<<<click here
APFS 90% 10% Audio on Both.
Pro Tools U-2020.5 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(2k10MP 5,1 / 64-Gb)
(Sapphire RX-580 MVC-Edition-dual mini 6 pin. one spliced to add Avid mini 4 pin-hdx)
FW-CoreAudio (for poly-recording)
(SSL-HUI-MIDIoverIP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
new systems builds / upkeep / +
New builds:
12 core nMP HDX 1 Slot 5 stock HDX Mac mini 6pin to 4 pin HDX power like 5,1 mp's used)
16 core nMP rack-test station
28 just because machine
Old 02-18-2013, 08:12 AM
Is there a way that doesn't involve me having to set up numerous audio tracks in ableton though, only to have to set up numerous tracks in PT.
At the moment I am using battery in PT, put samples in there and then can put that on an aux track and route out to various aux tracks. Can also combine samples, layering kicks for example to all go to the same aux.
The method of ableton I have looked into means I have to set up a lot of audio tracks and cant easily send different samples to the same aux I.e. 3 separate kicks would require three separate audio tracks in ableton.
Old 02-25-2013, 12:40 PM
Can anyone else shed any light on this ?
7.4, Rewire and Ableton Live ronwasserman Pro Tools TDM Systems (Mac) 1 11-09-2007 02:13 AM
PT and Ableton Rewire djdp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-07-2006 02:23 PM
Rewire /Ableton bassplayer01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-07-2005 07:07 AM
rewire problem in Ableton ekitel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-19-2005 12:58 AM
Ableton Rewire Pro Tools surefootedllama Tips & Tricks 1 10-09-2004 10:56 AM
