Old 05-14-2011, 11:56 AM
richeymcc richeymcc is offline
Default Keyboard Shortcuts Not Working!
Hi there,
I'm trying to use the shortcut to recall a memory location. For some reason it doesn't seem to work!
I have the Command Focus button pressed.
I'm trying "Period+MemNo.+Period". Whenever i press numbers 1-5 it just changes the zoom settings.
I'm on a macbook Pro- I have read elsewhere online that this just might be one of those things that doesn't work with laptops.
Any help would be much appreciated!
Macbook Pro - 2.33GhzIntel Core 2 Duo/2Gb RAM 677Mhz -
OSX 10.5.8
Protools 8.0.3cs2 LE Digi 003+Rack.
G-DriveQ 500Gb ext. hard drive 7200rpm- eSata- Partitioned
Old 05-14-2011, 01:00 PM
petmar petmar is offline
Default Re: Keyboard Shortcuts Not Working!
It works only with the number keypad. You have to buy an USB keypad or get an external keyboard.
Old 05-15-2011, 01:38 AM
Thanks- will look into that.
Also, do you know if there's any way to trigger memory locations recall via MIDI Controller.
I'm using backing tracks for live work, and need the most hassle free solution to go between memory locations.
Cheers.
OSX 10.5.8
Old 05-16-2011, 12:59 PM
Maybe the 002 or 003 consol have that function. But I don't think it's possible otherwise with midi controls.
Old 05-16-2011, 01:08 PM
bortraws bortraws is offline
Doesn't it work when you keep the 'fn' key pressed on the Macbook Pro while using the period and the U,I,O,J,K,L etc keys for the numbers??
It's an extra key that you have to press but that should emulate the numeric keypad. At least you can recall them while waiting for that USB numeric keypad order
Bortraws
Old 05-16-2011, 03:11 PM
Yeah, you'r right! Nice! Did not know that. So to recall marker 1 will be: fn+period, fn+j, fn+period. To insert a marker is fn+return (opens marker dialog)
To open the transport: fn+cmd+j and so on. Great, thank's!
Keyboard shortcuts not working with new iMac Undertones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 06-16-2015 02:34 PM
Some keyboard shortcuts not working in PT10 yop22 Windows 1 01-29-2012 09:11 AM
Keyboard shortcuts not working estudiomickael Pro Tools M-Powered (Win) 3 09-15-2009 03:05 PM
mac custom keyboard shortcuts not working FilterDecay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-13-2009 12:28 PM
keyboard shortcuts not working philippebruno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-30-2006 06:59 PM
