Old 01-20-2011, 08:00 AM
bashville bashville is offline
Default Possible prefs question relating to Heat install
I installed Heat last night and I'm noticing it doesn't seem to load the first time I open ProTools. If I quit ProTools, then open it again (no machine restart), there it is.
I'm assuming this might be a glitch in the preferences--can anybody make a suggestion which prefs file to trash?
thanks--
Old 01-20-2011, 08:22 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Possible prefs question relating to Heat install
thanks--
You are turning it on from the options menu??
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-20-2011, 02:18 PM
No it wasn't even showing up in the "Options" menu. It just wasn't loading.
If it loads, you get the "Activate HEAT" option in the pull-down. You can see it even greyed-out before you open a session.
Anyway, I trashed "DAE Prefs" which forced it to rescan all the plugs on startup, and now it's working. It must have been corrupt before, because it only would show up half the time.
thanks again Chris for answering--I just didn't want to indiscriminately trash all my prefs.
Old 01-20-2011, 02:50 PM
crizdee's Avatar
Yes the most annoying thing for me is my plugin favorites list!!
Worth noting that this app can also save orefs to be re-called for times like this!!
http://duc.avid.com/showthread.php?t=190122
Chris
Producer, Engineer,
www.ukmastering.com
bought heat how to install [solved] Filmusic Pro Tools TDM Systems (Win) 7 02-09-2013 07:43 AM
Console prefs lost since new PT9 install Mano ICON & C|24 1 01-23-2011 08:11 AM
What prefs and stuff gets trashed during 8.1 install? crizdee Pro Tools TDM Systems (Mac) 0 09-01-2009 01:56 AM
inquiries relating to Mbox Pro gfunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-15-2006 08:15 AM
(-5000) DAE prefs error on install nelsonmay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-03-2006 09:00 PM
