Old 08-05-2009, 03:55 PM
tim carter tim carter is offline
Default 192/Control24 and Hearback System
I'm curious... how are people routing their Talkback from a Control 24 through the Hearback Monitor system?
Mac G5, 10.5.8, 2 GB, Rosetta 800 w/X-HD Card, Control24, HD2, PT's 8
http://carterbrothersband.com/studio.cfm
Old 08-05-2009, 04:59 PM
BradLyons BradLyons is offline
Default Re: 192/Control24 and Hearback System
DON'T USE THE CONTROL24....run the outputs from either your 192I/O 8-outputs or your Rosetta800 outputs into the Hearback hub. From there, you'll just create busses and/or aux mixes. If you're confused---you know how to reach me :) I'd explain it here for the benefits of others, but I'm going to try and get some sleep for a change! This three hours a night is going to catch up to me someday.
Thank you, Brad Lyons
GC PRO- Pro Accounts Manager
(404)844-9758
blyons@gcpro.com
www.theaudioprofessional.com
Old 08-05-2009, 05:08 PM
Yes, I run lightpipe from the 192 into the Hearback... works great. I'm curious as to how others are treating the Talkback part... Go to sleep Brad.
Old 08-06-2009, 07:54 AM
SpongeBob SpongeBob is offline
Hey Tim ...
I also run optical from the 96 I/O to the Hearback unit. Pretty sweet ... frees up the analog ports.
From my C24, I run the talkback audio in to a PT audio track. As Brad wisely suggested, I route the 8 aux sends from that track to the ADAT out of the 96 I/O. That places talkback on each of the 8 Hearback channels. There is no other output for the talkback track, so you don't have to be concerned with the fader position.
The 8 aux sends going to the Hearback unit are named Phones 1, Phones 2 ... Phones 8.
Hope this helps.
Bob
PT10 HD Native (10.2.0), 96 I/Os, C24, Mac Pro (10.6.8 / 16GB)
Old 08-06-2009, 08:27 AM
Thanks Bob... I am routing the Slate out from the Control 24 to an aux track.. getting a terrible hum... I've been using this setup for sometime now.. but I just put in some additional hardward in the 192 and all of the sudden... hummmmm. Also, when you label your headphone aux's, are you having to do it for each session individually or are you going into the I/O somewhere...
Old 08-06-2009, 09:26 PM
jeff markham's Avatar
jeff markham jeff markham is offline
Aren't you limited to 48kHz then? I'm using analog on
our Hearback ..
Take the Aux output of the C24 (turn on Monitor to Aux.) for the
stereo A1-2 output plus the talkback .. and then 6 audio
outputs from an additional interface for instrument sends.
jeff
Old 02-28-2011, 01:25 PM
Perfection7 Perfection7 is offline
Hy, i just received my hear back and i have a 192, i connect the adat output from 192 to adat input hub, but the hub is not receiving the audio and on my 192 i can see the leads sending audio, i see the outputs sending !!
Does any one know how to setup the protools output our if it is any think else??
Thanks
Ed. Muniz
Connecting C 24 to a Hearback headphone system pcerrato ICON & C|24 7 03-01-2011 06:15 AM
C24 and Hear Technologies Hearback system? jeff markham ICON & C|24 5 02-28-2011 01:24 PM
HD2, Control24, Hearback and Presonus Central Station tim carter ICON & C|24 5 09-19-2009 10:58 PM
C24/002R and Hear Technologies Hearback System tim carter ICON & C|24 2 08-05-2007 12:56 PM
002r and hearback system therecordinghouse Tips & Tricks 4 07-20-2006 09:00 AM
