Old 08-03-2009, 03:59 PM
hydrophilos hydrophilos is offline
Default transport/counter/clock behaving strangely
The counter windows are not counting consistently. It appears as though the seconds are normal but the frames/tics have a jerking rhythm approximating 29-30 frames, then pausing for several frames and repeating this. A track/ sound playing is fine but the insertion line's movement seems to follow the frame/tic movement. Also, it behaves the same whether there is audio or not. Even if there are no tracks, the same too.
TIA
hydrophilos
I just upgraded to 8.0 (8.cs3)
2 x 2.66 Ghz Dual-Core Intel Xeon osx: 10.5.7
8 gb 667 MHz DDR@ FB-DIMM
SYNC I/O
Old 08-03-2009, 05:59 PM
Default Re: transport/counter/clock behaving strangely
Just noticed that when I drag a slider or enlarge a window it behaves similarly--its smooth; then pauses or cogs; then smooth again...seems to have to do with the refresh rate or updating of the screen/graphics card?
Anybody have any suggestions?
Thanks..
PT 9.0.5 behaving strangely after problematic install DougBesterman macOS 11 10-28-2012 05:44 AM
Odd counter/transport behavior TheHopiWay Pro Tools TDM Systems (Mac) 0 02-20-2010 08:30 AM
Pro Tools 7 transport counter & Mix LEDS freezes!! lenny ace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-02-2007 10:40 PM
Stuttering meters and transport clock bryanbassett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-22-2002 12:47 AM
Problem with Transport counter jitters DrC:drive Pro Tools TDM Systems (Mac) 2 04-22-2002 04:46 PM
