Old 03-05-2009, 09:29 AM
paranerd paranerd is offline
Default Cassette 'wobble' effect?
like an old cassette tape that's over-played and not very tight anymore. anyone know a good effect for that?
Old 03-05-2009, 09:39 AM
Nick Camaron Nick Camaron is offline
Location: Somewhere in the vicinity of Alpha Centauri, MW
Default Re: Cassette 'wobble' effect?
Definitely the "iZotope Vinyl".
It´s a record player simulation, but you can also imitate an old tape by leaving the crackles and dust stuff away.
Try playing around with the "Warp depth"and "Mechanical Noise" parameter
Great Tool... And its totally FREE
http://www.izotope.com/products/audio/vinyl/
Enjoy
Old 03-06-2009, 02:08 AM
tj_davies tj_davies is offline
I used PitchBlender to create a pretty good old cassette sound.
iZotpope Vinyl is not bad, but the Warp only works in AUDIOSUITE, and is fairly limited.
Timothy
G5 10.13.6
PT Ultimate 2019.12.0
www.pearls-music.com
Old 03-06-2009, 03:54 AM
manichouse manichouse is offline
Digi's Reel Tape Delay. Set mix to 100%, lowest delay time, and experiment with the wow and flutter controls.
Martin Trum
Old 03-06-2009, 07:18 AM
BroomPole BroomPole is offline
Two years ago I had the same challenge on my hands.
After multiple attempts on various plug-ins, I found the best solution was to find an old tape and old tape deck. Record the audio to the tape, while manually slowing the gearing on the deck down. Gentle movements on either spool really make some interesting effects! Make sure to dub the tape from tape to tape a couple times too.
Hope this helps
Cheers
Kevin
Old 03-06-2009, 08:05 AM
epm epm is offline
there's always a cassette deck and an old cassette :)
edit: whoops didn't see the post above.
-Evan
Old 03-09-2009, 01:58 PM
thanks for the replies!
an actual cassette and cassette deck would be ideal, yes, but the time and means aren't as convenient as i'd like. something similar would suffice in this case.
Old 03-09-2009, 04:02 PM
Danny Caccavo Danny Caccavo is offline
Reel Tape, as mentioned, but also I believe EchoFarm has a flutter effect. Are you going for that "Street Fighting Man" effect?
Danny Caccavo
(not at Digidesign)
Old 03-11-2009, 07:05 AM
Mubeau Mubeau is offline
if you have a pc there´s a lot of freeware via vst to rtas which does
that perfectly...
or simply route these fx through a VST host via adat or whatever...
http://www.freesoundeditor.com/VSTDelay-Reverbeng.htm
best,
mubeau
Old 03-11-2009, 09:22 AM
mbauer1 mbauer1 is offline
Audioease Speakerphone also has a good wow/fluter effect.
But as mentioned above, there's never a better substitute for the real thing.
An old tape deck will do the trick, and you'll feel more of a sense of achievement making it yourself.
Good Luck :)
Matt Bauer
www.bauer.net.au
E: matt@bauer.net.au
HTML code is On
SONiVOX Wobble help!? Friday0089 Virtual Instruments 8 07-21-2018 03:55 AM
SoniVox Wobble Dubstep Grime Generator Help!!!!! TawnTron88 Pro Tools M-Powered (Win) 0 09-23-2013 10:11 PM
Sync and Wobble digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-30-2010 08:09 PM
using 4 track cassette portastudio for Analog Channel effect DaveSB Pro Tools TDM Systems (Mac) 6 05-16-2010 03:15 PM
Quicktime Window Wobble in 7.4.2 musiceditorcouk Post - Surround - Video 13 08-15-2008 01:08 PM
